AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Elan Z630 - how does the remote work?
post #1 of 2
I just got one of these on Ebay. It came with a remote, but nothing else. I'm beginning to wonder if there is actually an IR receiver on the front panel, because the remote doesn't seem to control it. (I can see that the remote is putting out a signal though - it makes the LED blink on my Powermid receiver.) Is it necessary to connect an IR receiver module to the Z630 for it to receive commands?
Otherwise can somebody give me a clue about the buttons, if there is some magic sequence that makes it switch inputs, switch zones, control the volume etc.?
post #2 of 2
There is no IR receiver on the 630. You need to hardwire ir to the box.
  Back to Forum: Home A/V Distribution
