Originally Posted by Dstone001
David,
I've had the Decco for about a year. I'm far from an Audiophile, but it sounds great streaming my iTunes through a Airport Express and to Totem speakers.
My only complaint about it is the remote -- you really have to have good aim. (And the default to usb when the unit is turned on -- I don't use the usb input, so it's an unnecessary step.)
I wish I could afford to upgrade to the Nova when it comes out. But keep up the good work.
Cheers.
David,
Cheers.
Hi DStone,
You are right. The remote was not the greatest to say the least.
And even with the best intentions, ramping the volume down during turn on was not the best move.
We didn't specify the USB being the default, but we didn't specify otherwise, so this was just the way it was built.
Even with these annoying issues, the Decco will always hold a special place in my heart and I still love the way it sounds.
None of these issues are present in the Nova. We live, we learn, we build... Hopefully always improved over the one we built before.
Thanks for the input. Noted and applied.
David
