Hi all,
Thanks in advance for any advice/help. I have just purchased a Samsung 46" Series 6 TV, and am struggling with myself on where (and how) to install it.
It will be going into our family room, which is only 13' x 13'. The "front" wall has a fireplace with bookcase/shelving on both sides. (Our current very old TV is on a pull-out "shelf" on the right side of the fireplace). The "wall" on the left side of the room is really a railing next to stairs going down to the lower level. The wall on the right side of the room is an outside wall, with a large window. The back of the room is really open, into the kitchen and "sun room".
My primary location for the new HDTV is above the fireplace, but I have a couple of concerns. First, the fireplace (which is gas fired and rarely used) has a mantle, and then a wooden panel set back about 12" from the front of the fireplace--which goes across the width of the fireplace, and from the top of the mantle to the ceiling. There is dead space of about 18" behind this wooden panel before hitting the real wall. This panel is 3/4" finished plywood, and there are no studs behind it. The mantle is about 5 feet off the floor, which means the TV would be at about 63-64" off the floor.
My concerns for this location are two-fold:
1. Will the TV be too high for comfortable viewing? I will mount it with a tilt mount--and the sales guys at all the big-box stores say above fireplace mounting is not a problem with the tilts. Yet, I read that the ideal height is, of course, eye level at the center of the screen. Considering the room is small, some of the seating will be only about 6 feet from the fireplace wall. Will this work?
2. I've talked with the people that built the fireplace, and they think the 3/4 plywood should be strong enough to hold the TV and the mount. It would be a huge problem to try to get behind the panel to install studs. Looking at the various mounts, it seems the load could be distributed by installing many (8 or 10) screws holding the mount to the wood. I would like alternate wood screws with toggle bolts. Any thoughts on whether this would be adequate. The set weighs about 50 pounds.
Another alternative would be to mount the TV as above, but find an articulating mount that would allow the TV to be lowered as well as tilted. While that sounds like the solution, so far I have not been able to find any mount that will do this (I can find mounts for computer monitors up to 12 pounds). Is anyone aware of a mounting bracket that allows both side-to-side adjustment, as well as up-down adjustment?
Yet another alternative would be to mount the new TV basically where the old CRT TV was. It would angle from the edge of the brick on the fireplace to the right wall. It would "just" fit before bumping into the window on that wall. I'd need an articulating mount with at least a 22" reach to make this work. This is the worst solution relative to the number of good locations in the room to watch the TV.
Lastly would be rearranging the room so the TV would be on a floor stand, in front of the railing. We'd lose seating, and the TV would be facing a south window (which does have shades and drapes).
Any advice; the TV will arrive next week, and I'll likely try it in each of the locations before drilling lots of holes and managing wires.
Again, thanks in advance for any advice/help. If it would be useful, I will try to post a picture of the room.
Denny
Denny
