After gaming one night, I apparently forgot to turn off my plasma (Pioneer Kuro PDP-5080 HD) TV. I noticed that it was still on after about 3 or 4 hours later. There was no signal to the TV and everything else was off, so the picture was solid black.
I've had the Plasma for about 6 months now, so it's been broken in already. The picture seems fine other than the typical noise from the composite cables on my Xbox. However, I can't tell if the noise is worse than before. Did this degrade the overall picture quality of my TV?
Any input is appreciated.
Ok I can't even say that with a straight face. Like was already said...You should be ok. I would try to get to the bottom of the cable noise thing though.
