AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What would you rather get a samsung ln46a650 or a ln52a550
post #1 of 7
They are both pretty much the same price on amazon.... alright give me your thoughts guys thanks
post #2 of 7
I'm a firm believer in Bigger is Better having gone from a 45" to a 57" 2 years ago and the Wow is still there 2 yrs later. Even though mine predates 120Hz I'd personally never give up the size I have to jump to 120Hz that'll happen when I jump to the next gen 65".
In HT Size definitely matters and rewards one daily. Unless you have an extremely small room and lack HD Source I can almost guarantee that once you get the 46" panel in your home and you get used to the 46" within days or week you'll have buyers remorse in not going bigger.
Your Wallet so your decision but I'd go Big for that HT WoW!
post #3 of 7
I dont agree with Bigger is better.
If you look at the specs the 650 has ah igher contrast ratio, it utilizes the 120 hz and is an overall much beter television.
I was looking at the 550 and while not a bad tv it does has a little bit of motion blur and doesnt deliver as natural or has vivid of a picturre as the 650.
post #4 of 7
I'd take the 650 over the 550 any day, it's about the quality of the picture, not the size IMHO. I'm looking to get a new TV this holiday season to replace my 3 yr old Aquos and I'm considering the 750 or 860 TVs, going 46 or 52", depending on price of course, but it would be a big jump from my current 32" either way.
post #5 of 7
Now if we were talking 52 inch 550 compared to the 40 inch 650 then we would have more of a discussion but the 6 inch difference when its at your home really wont make a big difference.
post #6 of 7
Thanks guys
post #7 of 7
My 650 is smooth with 24p Blu-Rays but jerky in motion with 60Hz HD cable. I assume that's cause of the 120Hz helping 24p sources, if that's true the 550 may be jerky with Blu-Rays as well.
