Hi,
I have finished the first draft of my blend calibration software and I need to know how G2 and DRIVE (in Marquee terms) affect light output.
I understand generally speaking light output is:
L = K * (b + c *x) ^ G
Where:
L -> Light output
K -> Max value (would be a factor a Marquee's CONTRAST, I guess)
b -> Brightness (black level offset)
c -> Contrast
x -> IRE (from 0..1)
G -> Display gamma
What I need to know is how G2/DRIVE affect the above formula.
The reason I need this is b/c I am writing an automatic calibration software for CRT blends and I've found that the regular mode to do grayscale tracking on a Marquee (iterate thru 30/70 IRE readings) does not yield a very good BLUE curve - and I want to further correct this by using the ability to individually control SUB-GAIN bias introduced in latest marquee versions.
My software currently does:
- Measure light output for all 3 channels (R G B) from ~10 IRE to 100 IRE taking 20 samples in total (configurable). With this it calculates the gamma curves for R G B. Measuring low-IRE output is possible using a digital camera. I wrote the software to do this using a DSLR camera in RAW mode, so I read 16-bit readings off the camera's CMOS sensors.. Each reading takes ~30 secs, but the process is fully automated (you need two computers, the one measuring/controlling and a pattern generator server which I also wrote).
- It synthesizes a gamma curve assuming different low/mid/high gamma, and it creates an ideal blend curve based on that. I am using my Blendzilla right now, and I've gotten the best blend I've managed to get.
I'll post some screenshots of the software if you are interested. I also contacted TV-ONE in case they are interested in this software working for their units.
rgs - Andres
Where:
L -> Light output
c -> Contrast
G -> Display gamma
rgs - Andres
good news for all.
