AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › BluRay hardware player outputs @24 or @23. 976?
post #1 of 5
Does BluRay hardware player outputs @24 or @23. 976 if the source is 1080p@23,976?
And if Pioneer Kuro reports the support of 24, does it mean the support of 24 or 23.976?
Does anybody know?
Thank you.
post #2 of 5
Does anybody know?
Thank you.
They are one in the same. 23.976 is just rounded to 24 to make things easier on the consumer.
post #3 of 5
Actually, true 24 fps video is different from 23.976 fps (aka 24 × 1000/1001) video, but 23.976 is used for BD.
(Although people generally round to 24 and only specify the difference when necessary)
post #4 of 5
Apparently, there are some Sony players that output (an incorrect) true 24p, which tends to trip up certain outboard VPs.
post #5 of 5
There is no need to convert 23.976 fps on the disc, for NTSC display 59.94Hz compatibility, to 24.0 fps output. The Blu-ray Disc spec actually allows BOTH 24p and 23.976p HD video streams. Presumably BD players should support both and output what is on the disc without frame-rate conversion and likewise for HD displays nowadays to support both.
