Well, it's clear I still have much to improve re my calibration technique! I re-did my grayscale calibration tonight, taking more pains to try to place the I1 colorimeter in a position to get the max ftL. The highest I could get was ~10.5 ftL, which is quite a bit below what I measure at the screen with my CA813 light meter pointed toward the pj and x'ing via the screen gain(~18 ftL). I presume this is because one cannot place the colorimeter ideally to capture all the light coming off the scene. But since the calibration is a relative measure of the colors, hopefully it doesn't matter so much. ???
Anyway, as several of you suggested, I DID get quite different results than with my first attempt: RGB Gains are now (0, -39, -42), compared to (0, -16, -40) on first try.
And the RGB Offsets are now (-2,0,0), compare to the earlier (-5, -4, 0).
The Offsets I now get are actually very close to what Jason had in his initial calibration (-3,0,0), though my Gains have changed considerably from what he got, (0, -23,-75). Is it reasonable to expect that the Offset values would not change so much with lamp aging (mine now has 470 hrs on it), while the Gain values change more considerably?
I iterated back and forth between 100 IRE for the Gain measurements, and 30 IRE for the Offset values, as Curt Palme's guide described, and I'm quite confident that they are correct--at least with my I1 positioned as it was. Positioning the I1 is the last 'variable' that I'm least sure of.
If JVC does do a FW upgrade to make the CMS usable, I can see that the fun will then really begin.
). I want to get the most from my budget. Seems the Epson 750 is a great bang for the buck and a great all around projector. I am really after black levels and shadow detail.
