The problem I'm experiencing with my Panasonic DMR-T3040 recorder is the aspect ratio when I burn a DVD.
I want my recorder to record my programs in 720 X 480. HOWEVER when I record the programs on LP speed and EP speed I get other types of aspect ratios. When I record on LP speed the aspect ratio is 352 X 480 and when I record on EP speed the aspect ratio is 352 X 240.
I thought this problem would be solved if I changed the Hybrid VBR Resolution from Automatic to Fixed but when I do that the aspect ratio results are the same. Any help would be greatly appreciated.
