post #1 of 1
Two local channels were lost and the OTA signal strength is 0. I originally thought the antenna moved. But the truth is a few trees grew bigger and taller and blocked the antenna from the signal. Other channels had much stronger signal and were not affected even though they came from the same direction. The distance is about 12 miles. There is no way for me to relocate the antenna.
I wonder if adding a signal booster to the unamplified antenna (Square Shooter) will help. So far I found the following two and some people reviwed that the motorola one does not work on satelite signal or OTA signal.
PCT 1-port Bi-directional cable tv HDTV amplifier signal booster with passive return path
Motorola 484095-001-00 Signal booster.
