AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › How to find my old theater construction thread?
post #1 of 5
Alright Guys,
It has probably been over a year and a half since I last posted on my theater construction. However, over the past few weeks construction has FINALLY begun on it. But there is one problem.....
I can't find my old thread! I looked under my accounts, all of my posts, etc. It is completely gone. I don't want to start anew one since it had become quite long and helpful. If you guys could help me find it, that would be great! Thanks!
post #2 of 5
check the archive
http://archive.avsforum.com/avs-vb/
or
http://archive2.avsforum.com/avs-vb/
post #3 of 5
Thank you so much!
Would it be allowed for me to take some of those older posts and post them in a new thread here?
post #4 of 5
Sure. Why not? This isn't the Gestapo
post #5 of 5
If you click on your name...your link to your profile comes up. Within your profile under stats...is a filtered search option for all your posts and all threads started by you.
