AVS › AVS Forum › Audio › Speakers › Speaker palcement question for center channel......
post #1 of 6
My question is this, how important is it to have the center channel at ear level? If I mount on top of tv, it's gonna be about 8.5' in the air. The speaker does have an adjustable tweeter but the angle doesn't seem to be very great for pointing downward. The delima is this. The thing is high up to begin with, top of mantle is about 5.5'. I was very leary when my wife suggested putting it up there(on its own factory pedistal). Well I said I would try it up there thinking our even our necks would hurt looking up at it from the couch(we are both 6' tall). Turns out that it works just fine at that height. Now that I am finally mounting it w/ in wall speakers etc. I have bought 3 of the yahama NS-IW760's that will be for R, L & Center. The center channel is what I am concerned about. The speakers are about 8" tall & I was planning on putting it below the tv & on top of the mantle. The problem is, that would raise the tv another 7" which doesn't sound like much but it looks scary high. As always, any suggestions welcome!
post #2 of 6
the audio carried by the center channel is very directional, so mounting it high on the wall "may" be a concern. If you can mount it in such a way to angle it down towards the listening area, it could work fine. The best way to find out is to just experiment with the location. It all comes down to the listener's perception of where the vocal audio is coming from. If you can discern the voices are "above" the TV, then it will seem disconnected with the actors on the screen, but only your ears and the experimental positions can determine that
post #3 of 6
I suggest you install the L/R's first and try "phantom" center channel. (Tell your receiver you have no center channel, and it will distribute the center channel info between the L/R speakers.) See if that works for you. The only downside is that your listening positions are more restricted. You need to sit between the speakers, preferably in the middle, to get the best effect.
Craig
post #4 of 6
with reference to the "phantom center"....I did try that with my son's initial HT setup and neither he or I liked the results. We cheated ! Found a much smaller center channel speaker based on "fit" rather than matching the L-R fronts and used it. In no way can you say it's "timbre matched", but in the real world, it worked for movies, the majority of his viewing. Just a thought......
post #5 of 6
There are 2 things for you to consider regarding your center speaker's height:
1.) How high is it relative to the height of the TV?
2.) How high is it relative to the L/R speakers?
If I understand correctly, since your TV is already mounted high, the center speaker will be high, yes, but it will be just above the TV, correct? If this is the case, then the speaker's location, at least in relation to the TV, will be OK.
Now, will your in-walls straddle the TV? If so, then, basically, your entire setup, speakers and TV, will simply all be a bit on the high side. Optimal? Maybe not. We all usually have to make certain compromises. But the relative height of the speakers to the TV and the center speaker to the L/R speaker will be OK.
If your TV and L/R speakers were 3' high, but your center speaker was at 8', then this would be a concern. But as long as everything is at a similar relative height, you should be OK. If your center ends up really close to the ceiling, you may have some issues.
As best as I can tell, in looking at the pictures of your speakers online, it appears that the tweeter will be equidistant from the top and bottom (when used horizontally) of the speaker. If this is not the case, you may want to mount the speaker in the orientation that places the tweeter closest to the TV.
edit: I found a better online pic and, unless Yamaha instructs otherwise, it shouldn't matter which way you mount the center speaker. If the swivel mechanism is directional, and all the speakers will be above ear level, then mount all the speakers in the orientation that will allow you to tilt the tweeter, as best as possible, downward toward the plane of your ears.
post #6 of 6
Thanks for the responses. I did end up with the cc underneath the tv. It raised the tv up about 8" but if I had put the cc above it would have been about 8' in the air. Even with the tilt of the tweeter i was afraid that it would still be too high. I should get my "faceplate" back from the millwork company this week & hopefully have it installed this weekend. I will post pics once done. It should be very unique to say the least. Now i get to upgrade my receiver, this is just too much fun! I do so much research on these purchases I feel like its a second job, but i love this seconod job.
  Back to Forum: Speakers
