I have a question regarding a newly built media center pc that is connected to a Mitsubishi WD-62327 HDTV. The mpc has a Geforce 7100 DVI connector. The problem is that when I connect the system to the HDTV I do not get the native 1280x720. The resolution appears fine when I plug it into my lcd monitor but as soon as I connect it to the HDTV I get really bad options for resolutions.
Things I have tried.
I tried creating a custom resolution through the Nvidia control panel. All desired resolutions failed to establish.
I tried using the software PowerStrip to get a custom resolution to no avail.
Things I have not tried
Getting a better DVI cable. I currently have a DVI-D (Single Link) cable. The HDTV has the ability to accept a DVI-I (Dual Link) cable. Would this make a difference?
Going from mpc SVGA to HDTV DVI?
Any help or suggestions would be greatly appreciated.
