Originally Posted by
candre23
Wow, I wish I knew about this before I set up my WHS server. This looks a heck of a lot easier to use than unRAID.
Yep, FlexRAID is quite simple and flexible.
Many users use FlexRAID paired with WHS.
candre23
Do you assign one or more drives as parity-only (drobo-style), or is parity info spread out across all drives (RAID5 style)?
You assign one or more drives as parity.
The parity drives can contain other data, but it is best to keep the parity drives for parity data only if you can help it.
You can use the free space from many different sources including network shares to host the parity data.
So, yeah... drobo-style (but much more flexible) and not RAID5 style.
candre23
Can you add new drives to the pool at any time? If the new drive is larger than any of the others, do you need to make that the new parity drive (like Drobo), or is parity sorted out automatically?
Yep, you can add more drives to the pool at any time.
You don't need to make the new drive the parity drive.
However, the parity space must be as large as the largest drive.
Note that I said "parity space" as you can assign multiple smaller drives, network share space, etc as "parity space".
So, use your best and newer drives for data and your old and smaller drives for parity space.
