AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Got the projector, now I need a screen
post #1 of 6
Hey guys,
We just purchased a Sony VLP AW10. In the theater room, the throw distance is going to be roughly 14-15 ft. and I'm looking for a 90-105 inch screen. A motorized screen isn't necessary, but I'd like to make sure that the screen does stay flat. Also, I was advised on using a "silver screen." Supposedly it brings out better colors from the image? Anyways, our budget is around the $200-500 range, though I don't know if we'd need something of that quality since the projector isn't exactly high end.
Thanks for your help!
post #2 of 6
Check out the screen forum down below. You will spend more for a pre-fab fixed screen then you budget allows so you I would suggest you take a look over at the DIY screen section. You will get some great advise just like I did.
post #3 of 6
Oh my bad!
I didn't even notice there was a forum for screens. If a mod would be so kind as to move this thread?
Thank you!
post #4 of 6
post #5 of 6
Bad advise. In the 92" to 106" range he can buy a fixed frame from the following:
DaLite
EluneVision
Elite
Focupix
I paid less than $350 for a 106" fixed frame screen with 3" velvet frame. If the OP wants any info he cam PM me.
There are many others. I just remembered Mustang.
post #6 of 6
