AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Comcast cable box settings keep resetting
post #1 of 3
I have my comcast cable box hooked up to my Onkyo S7100 home theater and whenever I turn on the receiver, the settings I have set in the cable box's menu (1080i, 4:3 stretch) are reset to 720p and 4:3 standard. I have to change them back every time I turn the receiver on. Is there any way to fix this?
post #2 of 3
Bypass the receiver and run direct to the TV. If problem persists... get the cable box replaced.
post #3 of 3
All of the cable boxes here(Moto 6412,6416) do it...when connected via HDMI.
Each "handshake" when you change inputs,power on,etc. resets the user menu options to default.
I solved the problem by using component,and digital coax out for sound.
  Back to Forum: Cable, Digital Cable - Non-HDTV
