AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › How did you mount your surrounds?
post #1 of 3
I have seen surrounds hanging directly on walls and some on shelfs. If wall mounted, how did you prevent vibrations from sub. I need to mount 4 Klipsch s1 surrounds. They only have one keyhole slot and I thought about putting the little silicone bumpers on the 4 corners. I might do this now and later on build small shelves the curved shape of the speaker to sit on if that is better. Which way is best?
post #2 of 3
My Paradigms are wall-mounted, using the provided cleat/brackets. The speakers themselves came with the rubberized cushions, and so far have never made so much a squeak during heavy LFE tracks. I think any rubber feet attached on the wall 'contact points' will certainly help you keep your Klipsch surrounds tamed!
Cheers,
post #3 of 3
I mounted them just behind the seating position. To become less intrusive I just dialed the rear volume down. Works great in my setup and I didn't want speakers hanging high in the room.
Victor
