I just got this projector but I'm not too experienced with projectors and was wondering if some of you guys could help me out.
I have the projector at a normal level setting and its projecting onto my screen. The only problem is that the projected image kind of slopes in a little bit and i can see some black areas on the side because the image isnt filling all of the area.
I was wondering if there was a way to correct that. I tried the vertical and horizontal shift but that just seems to move the image a different way and the image is still not in the right proportion it needs to be.
I could just not be doing something right with that but any advice would be greatly appreciated.
