I described earlier the experience of losing access to the PC's Hardware Audio signals like CD-IN and Composite Audio when switching from Windows XP to Windows Vista.
This OS switch disabled critical functionality used by TV Tuner cards like Dvico to allow usage of the Composite input from the Cable Set Top Box to the PC in order to allow encrypted signals which the user is paying for to be viewed on the PC, through the Composite Video 3 pin interface.
In addition, this problem prevented the audio being output to the PC Speakers being segregated into 2 preliminary input paths, Wave and CD-IN or Wave and Line-IN, which allowed these 2 paths to be audio-volume balanced, as would be the case in any living room between the TV and the Stereo Receiver.
I was forced to retreat back to a Windows XP installation to regain this Hardware Audio functionality.
At the time I thought this was just another Bug in Vista.
(As a side issue, I already mentioned the addiitional Vista Bug in the additional failure to implement the Ctrl-S sizing feature in the new SNDVOL.exe which was in the XP SNDVOL32.exe applet, which is even more necessary in the Vista applet version.)
However, I recently had occasion to upgrade my Asrock motherboard from the BIOS of a year ago to the current BIOS and encountered the identical symptoms.
I had to retreat back to an older motherboard BIOS version to regain this Hardware Audio functionality.
This sequence of events indicates that there is a clear policy being driven by Microsoft and their lackeys at AMI to block these Hardware Audio signals from the PC.
If Microsoft is responsible for this, the manager there responsible should be Fired.
I want to know if this is an announced policy, and if so, what is the reason for this ?
