AVS › AVS Forum › Video Components › Home Theater Computers › Blocking of Hardware Audio signals by Microsoft/AMI
Blocking of Hardware Audio signals by Microsoft/AMI - Page 3
post #61 of 157
Originally Posted by jvincent View Post
And you made my point. Back to lurking on this thread.
You have not made any point.
Show me any thread where you have suggested modifications to core (not fringe) functionality of the PC TV, as important as what is in this thread ?
post #62 of 157
Originally Posted by Aeneas View Post
Simple. To again present this problem as one which needs to be fixed...
To whom? None of the "real PC TV users" (tm) here have any ability to fix it whatsoever. And when directed to someone who might have some ability you ignore the suggestion.
Do you really expect anything to change by posting here?
...and challenge anyone to refute my arguments that this is a serious problem with the PC TV context.
So you're here to argue and place blame....
post #63 of 157
This problem is not going to be solved without Microsoft putting conscientious workers in position to fix these problems and a realization that top management at Microsoft simply may not even be aware of how incompetent their mid-level management chieftains are in steering their multimedia business.
These mid-level chieftains at Microsoft need to be Fired, and also, I do not believe that the problems will be solved any other way.
I have described many problems, but there are many more I have not had time to detail.
The problem needs to be dealt with at its root.
The Microsoft multimedia managers need to be Fired by the top management there.
I want to continue to stress that what I have talked about here is core functionality.
Down-the-middle stuff which any conscientious worker in Microsoft Multimedia could not possibly miss.
post #64 of 157
I remember navigating that menu and the CD-In device was not available in the list, even though there was definitely CD-IN on the motherboard which the Windows XP installation on the same system was able to find and allow Dvico to present.
CD-in will be by default disabled. You need to show disabled and unpluged devices by right clicking and selecting show disabled and unpluged devices. If a newer BIOS has an incorrect pin-config that does not have the CD-in you will need to go back to the old BIOS or ask your PC manufacturer about how to fix it.
I checked another PC in my house that is AC97 and it also shares the CD-in with the microphone. I believe this was a common design practice in the XP days.
As for relative volumes and the windows sounds, you can use the per app volume control in Vista (sndvol) to adjust the windows sounds to a relative amount.
I hope this helps.
-Rian
post #65 of 157
I hope this helps.
-Rian
This does not make sense. You are claiming that Vista, which was designed with HD Audio compatible chips in mind, would disable known audio input ports, when we know that all of these ports are explicitly supported by the HD Audio 1.0 specification.
The Vista code must be written to assume the simultaneous presence of the following supported signals:
Microphone, LineIn, CDIn, AuxIn and S/P-DIF In
That is in the spec.
Both the ALC888 and the AD1981HD have separate pins for these inputs.
In fact, it looks like the Microphone is stereo, incompatible with the CD-IN signal.
post #66 of 157
Vista will not by default show inputs that cannot be used. Just because there is a pin widget doesn't mean that a converted is available for that widget. In a typical PC the CD-in is muxed with the microphone so if the microphone is selected the CDin cannot be used.
Vista and the HD Audio spec support all of the inputs that you mention above. Not all codecs support these inputs and not all of them support them simultaneously.
Vista is a platform and must be designed so that multiple programs maybe run at the same time. If one program tries to select the microphone while another is using the CD input there would be a conflict. I was not around during the Vista design process so I can only guess as to why Microphone was chosen over CD-in
There is a good explanation on why the CD Audio input is not being used as much in David Roach's book "High Definition Audio for the Digital Home." The basic explanation is economics. The cost of the quasi diff input that is used for analog CD audio and the cost of the support calls from confused user are considered to be too much. This book will also give you a good understanding as to how HD Audio works.
-Rian
post #67 of 157
First it was closed caption support...on a different screen...and that too scrollable...now this...CD_IN....sigh...
post #68 of 157
-Rian
I am not interested in knowing the details of some guy's prattling about what he thinks HD Audio is about. That does not address this issue, which is that the pinout is on every motherboard I have encountered, including new ones, to allow TV Tuner cards to connect CD-IN to the motherboard to allow the motherboard Audio chip to receive this signal and allow that input to be used for TV Tuner audio input.
Furthermore, it should have been possible to determine whether or not the pins connected to the MIC or CD were floating or connected to a device. That should have governed what selectable devices showed up in the Vista menu in question.
Microsoft's long term audio technical partners Creative Labs have reserved a prominent top edge position on their Soundblaster, as I have already shown, for their CD-IN connector to allow explicitly adjacent TV Tuner cards to connect this CD-IN signal directly to the Soundblaster card's Audio mixer chip to perform the same function.
I would be interested to know where you are seeing in the specifications that CD and MIC are an either/or activation.
Interesting that you have not named a few motherboards which document this limitation, yet.
The motherboard differential amplifier used for the CD-IN signal is for the motherboard manufacturer to implement and they are continuing to implement it in order to deliver this signal to the audio chip.
post #69 of 157
I have never said anything about a different screen, ever.
That is total waste.
Closed Captions in a separate External Window, as was implemented by ATI in the All In Wonder line, should be implemented in all TV Tuner implementations.
This allows the user to scroll back the Closed Captions if they missed a particular word or were on the phone for 1 or 30 minutes or more, allows watching lyrics of songs or speeches when the accent or delivery is hard to understand, allows search for a particular word, allows language translation of the words live or operating on the Recorded CC file saved by online translators, etc.
It does not make sense that free extra information about the show you are watching is not presented in as useful a manner as possible in a separate window, a window which can be tucked out of sight behind other windows until needed. That way it can be active 100% of the time without obscuring the TV picture.
I am amazed that Microsoft themselves have not yet implemented this separate External Window for Closed Captions and given it away as part of the OS.
Especially since Closed Captions are legally required.
What the heck have Microsoft Multimedia managers been expending those limitless engineering dollars on over the past 3 years ?
Microsoft Multimedia managers must be Fired and replaced immediately.
post #70 of 157
If you know so much more about this than everyone else, learn to code (or hire some developers) and make your own software/hardware. If you're right that everyone's ignoring a massive, untapped market, you'll be rich in short order.
post #71 of 157
You think I should go into the Pothole filling business if I think the city is too slow in filling the potholes with the monies they have at their disposal ?
Just imagine all those businesses we all could get into, when huge companies millions of people depend on, malfunction.
post #72 of 157
This thread is hillarious.
Props to Rian for actually respectfully responding and trying to explain things.
post #73 of 157
The problem with all of your posts is that instead of asking for answers/help with resolving your problem is that nearly every one (I'll admit, I haven't read them all) contains some diatribe against Microsoft and it's managers.
If you state your problem simply and factually without invoking some grand conspiracy theory, you will be better off.
You forgot that AVSForum is filled with people being paid by "the industry" to lead people astray.
Man...I need to get in on that money maker!
post #74 of 157
Now here is a guy who knows what he is talking about.
However, dirty money is dirty money -- leave it for the criminals.
post #75 of 157
In all seriousness.
Can you restate the issue? Please do it in the following format:
Problem: Short description of the problem, for example "hard drive does not power up"
Expected Results: Describe, in detail, what you did and what was expected after doing it. For example, "plugged hard drive power connector into hard drive, expected hard drive to spin up.
Has this ever worked? If so, when?: Explain when it last worked and what was done to make it work, if it has worked in the past. Please also list what is different between then and now. What has changed? For exa,mple "It worked last week. The only change has been to remove the large black cord which connected the PC to the wall outlet."
Troubleshooting Steps: Describe, in detail, the steps you have already taken to make this work. If multiple items were done, seperate them into different paragraphs.
This will help clear things up. Please keep out any irrelevant information, such as "Federal Agents have paid Ugandans to prevent this from working". That adds nothing but confusion to the issue, even if you honestly believe Ugandans are preventing it from working.
post #76 of 157
In all seriousness.
I have described the sequences of events which led to the loss of Hardware Audio signals such as CD-IN and Composite Audio.
In the most recent scenario 2 weeks ago, I upgraded the motherboard BIOS to last month's release and immediately lost access to the audio from CD-IN and Composite on the Dvico FusionHDTV5.
I reinstalled the old motherboard BIOS released a year ago, and then Dvico could again receive audio from CD-IN and Composite Audio.
When people on a forum like this claim that that is not an important development, they cannot possibly truly be the Real Users they pose to be here. That fraud needs to be exposed otherwise it Confuses the role truly Conscientious workers at some of these companies must play to recognize serious problems and solve them.
There are scores of people working at Microsoft right now who are being paid 6 Figures to solve problems just like this one, Not create them.
post #77 of 157
There is no such thing as "Composite Audio". It's analog stereo and it's usually pair with a Composite VIDEO connection. It's also not "2 pin" audio. It's two connectors with a total of 4 pins. Each connector has a signal and a ground pin. Sometimes the ground pins are combined.
When people on a forum like this...
It's called the A/V Science forum.
... claim that that is not an important development, they cannot possibly truly be the Real Users they pose to be here. That fraud needs to be exposed otherwise it Confuses the role truly Conscientious workers at some of these companies must play to recognize serious problems and solve them.
You have already exposed that fraud. It was already established that we are not "real users" when it was revealed that none of us use Windows Movie Maker 2 to edit H.264 files.
Actually, the people making 6 figures are probably being paid to hire people to solve them. (I wish I could tell you from personal experience.)
It's Christmas, Aeneas. Have some eggnog and think about a New Year's resolution.
Now where's that ignore setting?
post #78 of 157
In the PC context, there is no such thing as Composite Video, alone.
Where have you seen a Composite Video plug fed into a PC without the 2 pin audio along with it.
This 3 pin interface, if you actually used PC TV Tuner cards, which is the only thing we are talking about here, like Dvico's, is called the "Composite" Input Source.
Both Dvico and Asus use the same cable which includes these 3 pins plus another one which if I recall correctly is an S-Video connector.
On the back of the 3250HD Scientific Atlanta Set Top Box, the corresponding 3 output pins are lined up in a vertical column together of 3 pins, white, red, yellow.
This is how SciAtl describes these 3 pins:
"8. Video and Audio Out: Connect an RCA cable to Video Out and Left/Right Audio Out to send analog video and audio signals to a standard TV or VCR. This signal is SDTV."
Clearly this wording implies that even Consumer Electronics devices treat these 3 pins as a 3 pin set.
It is absurd to continue to classify Composite Video as a separate technology.
There is no way that any HR person at Microsoft responsible for Multimedia hiring is actually earning that 6 figures, if in fact that claim is correct.
I remember that issue with Windows Movie Maker 2. At the time, I was accused by members of this forum of being a Microsoft supporter.
On forums like this, so many of the participants are accustomed to reading mouths who are bought by one party or another. It is confusing for many of these people to believe someone is simply here to tell the truth, wherever it leads.
post #79 of 157
So you already fixed the problem. You reverted to an older bios which does not have the problem the new bios has. I have reverted to older bioses before, and older drivers before, when the newer versions made my problems worse instead of better.
It could be a purposeful issue by the motherboard maker to free up resources for other uses, could be purposeful to remove support for something that almost no one uses anymore, or could be an accidental bug. They probably did not bother to test something that almost no one uses any more.
I am still not sure it was done purposefully to prevent the small number of users from doing the types of things you are doing. I see it more like the floppy drive. Sure, there are a few users out there who still use one, but more people no longer care about it.
The primary purpose of the CD_IN connector was to allow the first generations of CD-ROM drives to play music. They could not output digital sound, so they sent analog sound out to the CD_IN connector on your sound card (and later on the motherboard) so it could be heard through the PC. Eventually, CD-ROM drives started appearing with a digital out connector, then both connectors went away in favor of passing the sound over the data bus. The primary use for the CD_IN connector was no longer needed.
During the time it was widely used, some manufacturers started to use it for other purposes. It was easy and convienent. The problem is that when it was no longer needed for its primary purpose, support for it started to vanish.
That is the thing, is it really a problem? Sure, it is a problem for you, which makes it very important to you. I would feel the same if I was in your position. But the issue is that it is an ancient connection which no longer serves the reason it was created. Since CD players no longer need the CD_IN connector, it is being slowly phased out.
I think you need to find another way to do what you want to do. I truely think you are on the losing end of an obsolecense issue.
View it as a challenge, basically say f-you to those who are removing something you want to keep using and create a work around. Post it on the web for everyone to use as a way of circumventing them.
post #80 of 157
Reinstalling the old BIOS version is not a solution to the problem.
There needs to be a federal prosecutor driven investigation into this theft of functionality out from under the user who has already paid for this functionality. That is a crime.
And the Microsoft manager of multimedia responsible must be Fired immediately.
The sequence of events makes clear that future motherboards will not allow the CD-IN signal or the Composite Audio signal to be used by the user.
There is no reason to obsolete these signals and I do not see anything that Microsoft is positing to replace them.
There is no new functionality in this motherboard available after the upgrade.
In fact, when one looks at the page on the motherboard web site where the upgrades are listed, there is no detailed description of what has changed in each upgrade.
This is a scam. A Microsoft/AMI driven scam.
And a high proportion of Microsoft's customers simply cannot afford to be ripped off.
They buy their house PC as a 5 year or more investment and cannot afford to add anything else to it or purchase and install a new Operating System (OS).
The purchased computer system must work and continue to work. Anything that Microsoft is doing that inflicts a type of forced obsolescence must be treated as a serious crime and those managers responsible must be punished.
Federal prosecutors should put the development managers of these 2 companies under oath before a Grand Jury to ascertain the truth and find where the fault should lay.
There are 100,000's of users using the CD-IN signal to decouple the TV Tuner audio and allow it to be volume controlled individually.
The rest are not aware that this can be done.
Claiming that no one is using the CD-IN signal, when the main audio card manufacturer, time-honored Creative Labs/Soundblaster, still reserves its most prominent top-edge position for this CD-IN connector, is nonsensical, and indicates a determination to defend Microsoft and AMI which must indicate that this is determined paid public relations work on your part.
I am well aware of the origins of the CD-IN signal, but its presence on the motherboard has evolved into much more critically important usage. And that is why Creative/Soundblaster reserves its prime connector position for this CD-IN connector and describes its purpose as being for TV Tuner cards, Not CD Audio players. (e.g. Sound Blaster® X-Fi™ Xtreme Audio)
http://support.creative.com/manuals/
"5. Aux In connector Connect an analog CD cable (available separately) from the analog output on an audio device like a TV tuner to this connector. "
Again, attempts to marginalize the core functionality of CD-IN and Composite Audio simply bring into stark relief the absurdity of discussion in forums like this where discussion is dominated by public relations workers.
Do you see anything that Microsoft has done so far, even in the newer operating system Vista, to solve the problem of loss of Composite Audio in and allow the user to receive the Composite Video/Audio signal from the Cable Set Top Box ?
post #81 of 157
This has to be the funniest post I have read in months.
Merry Christmas and Happy Festivus to all.
post #82 of 157
Christmas it is. No idea or interest in knowing what Festivus is.
Maybe this is what Microsoft spent their Multimedia engineering budget on over the past 3 years:
working real hard to prevent their customers from receiving Cable content with this Cablelabs-based OCUR/CableCard crap architecture they have implemented in the Windows Vista operating system.
As I mentioned before, Microsoft should go back to these new found friends they have in the Cable industry and present them with a USB interface protocol specification to allow the PC to control the output channels and various other internal operations within the Cable Set Top Box.
There is a need for a reliable method to control the channel(s) output by the Cable Set Top Box (amongst numerous other operations within the STB) and infrared IR Blasters is nowhere near reliable.
In fact, with the Hauppauge HD PVR, this IR Blaster functionality does not work at all, even with the industry dominant 3250HD Set Top Box from Scientific Atlanta/Cisco.
Cable Set Top Boxes should be capable of outputting several decrypted output channels at once, some NTSC, some 1280x720 under the control of the PC.
Microsoft needs to Fire the incompetent Multimedia managers there first before entering into these negotiations with the cable industry.
post #83 of 157
You should look up Festivus since you clearly have some grievances that need airing.
Did you read the posts where it was explained that the cable industry are the ones that are putting all of the restrictions in place for encrypted digital signals?
They are the ones that have made Microsoft create all of the secure pathways in the OS. If it were up to the cable companies we wouldn't be able to watch anything on our PCs.
The same is true of the movie studios when it comes to DVD and BluRay too by the way.
post #84 of 157
I am well aware of the motivation behind OCUR. However, as is clear from the reaction to the ATI OCUR product offering and reactions of people even on this forum, the architecture on the PC is too restrictive and thus no one wants to use it nor buy it and thus the Windows OS software support for this OCUR architecture was a waste of money for Microsoft to implement.
Microsoft along with Intel represents the PC and, as a huge entity wields enormous market power. For Microsoft to be pushed around by the cable industry in this way as to waste its resources implementing such a restrictive TV Tuner reception architecture indicates that Microsoft is not making proper use of its market power.
That is exactly one of the reasons why I have recommended that current Microsoft Multimedia managers be Fired before Microsoft proceeds further in this Cable TV connectivity area.
Microsoft needs to flex its muscle in Washington, DC and with the Cable industry to fix this problem and allow acceptable freedom to return to TV reception into the PC, in this new HD era.
There was a time 15 years ago when NTSC signals were all scrambled by the cable industry. That was only freed up by Congress and legislation.
Microsoft needs to lead this fight again, or they will lose money and Microsoft's customers will lose practical access to the TV signal for the PC
post #85 of 157
What the heck, I'm just digesting turkey now anyway.
You realize of course that the percentage of revenue that Microsoft gets from HTPC usage is miniscule right? They have much more important things to worry about than a handful of enthusiasts who want to watch / record TV shows.
But wait a minute, those people can already do that. The overwhelming majority of those people are doing just fine. I'll bet that less than 0.0001% of HTPC users actually use the CD-IN port.
You should also be aware that mid-level managers at MS really just do what they are told right? They certainly don't have the time to go off trying to change the industry. Even if they did, they wouldn't because there is no ROI in it.
post #86 of 157
Yeah, I mean, who wants to Watch TV, right ?
And here I am on this TV-oriented forum with thread after thread about what is called an HTPC and I have zero interest in it, have never read any of those threads, and I could not tell you or anyone what an HTPC is.
Yet here I am talking about $50 Tuner Cards and their interface to the PC and Windows.
And one thing is clear: anyone who does not recognize the importance of CD-IN (and Composite Video/Audio) to the TV Tuner interface to Windows XP, simply does not use these products in truth, has not really had the practical experience to Watch TV on the PC, and is really just posing as a Real User on this forum, while performing some sort of public relations role not driven by genuine personal interest.
Usually this faked interest is propelled by covert pecuniary inducement.
post #87 of 157
And one thing is clear: anyone who does not recognize the importance of CD-IN to the TV Tuner interface to Windows XP, simply does not use these products in truth, does not reall know what it is like to watch TV on the PC, and is really just posing as a Real User on this forum, while performing some sort of public relations role not driven by personal interest.
Usually this faked interest is compelled by covertpecuniary inducement.
When I used to watch/record TV on my PC, I first started about 5 years ago, I didn't use the CD-IN port. I expect most people didn't either.
Why do you have such a hard time accepting that the overwhelming majority of users don't care about that functionality.
You know what I'd like? For my 6 year old PC to play BluRays. I guess I should ask for a bunch of MS managers to be fired for this too because they are part of the grand conspiracy.
post #88 of 157
That is because you were not aware of how to use Hardware Audio sources like CD-IN or Line-IN with your TV Tuner card.
And because of this ignorance, you most like turned your TV Tuner off for large periods of time while listening to MP3 files, YouTube, movies clips and Windows' own audio generation itself.
Your TV Tuner experience with your PC was damaged by that ignorance.
Interesting you mention Blu-Ray. As I mentioned, I bought one as a lark (and to gather information, in truth) and a current movie to check it out.
The Cyberlink PowerDVD BD included software is giving me an error that it does not recognize my ATI 3850 brand new drivers.
I then downloaded and installed a 6 months old driver and it claims now that my 1920x1200 DVI monitor is incompatible with its output.
This is incredible.
However, other than this lark and information gathering, I have zero interest in Blu-Ray, as is true of most people who have any resistance to the media bombardment about this snazzy new technology.
post #89 of 157
Your TV Tuner experience with your PC was damaged by that ignorance..
You do realize that the Vista sound mixer now has per-application volume control in software, right? Wouldn't that be a better way to solve this problem vs. a hack using an obsolete hardware interface?
post #90 of 157
I am well aware of this.
I was the one who recommended Windows XP implement this functionality 3 years ago.
On this forum, in fact.
For some reasons, the chieftains who run this AVS forum have decided to put those messages in a remote archive and thus access to those messages is not readily available.
However, this solution was not implemented in Windows XP.
And also, the Windows Vista implementation has Bugs which prevent Composite Audio from being Recorded.
Files recorded from the this interface to the Cable Set Top Box have video, but are Muted.
This thread is locked
