A power supply with battery backup is even better than a surge protector.
I wouldn't run my PAL (or my computer) without one.
+1
ALL DVRs (as well as PCs) go on UPS's, not just surge protectors. A DVR is just a specialized computer. |
Not disagreeing, just requesting clarification/justification:
We are concerned about two negative outcomes caused by unreliable AC line power: 1) Damage to our hardware. 2) Loss of "work" in progress. AFAIK, a surge protector and an UPS (with equivalent joule rating) do an equally good job at preventing #1, correct? Obviously only the UPS can prevent #2. If the above assumptions are correct, then the only reason to prefer an UPS over a surge protector in the case of the DVR is if you are concerned about losing some/all of a particular recording due to a power outage right? If so, then a reasonable person with fairly reliable AC line power who does not consider any particular DVR recording to be "critical" might reasonably decide that an UPS is not justified for the DVR, right? Please let me know if the logic above is flawed or based on erroneous assumptions. |
I'm confused. In your first post about this issue here, you said your recordings were starting late. This would indicate the clock was late. That message was also in response to someone whose clock was 7 minutes late. Now you say it is late, but was previously early, which is different from what you posted a couple of days ago. The significance of this is that if your clock was early before, then this is not the same issue as what Austin sees. Their clocks are either on time, or late, but never early.
