AVS › AVS Forum › HDTV › HDTV Recorders › The Official AVS Dish DTVPal DVR Topic!
The Official AVS Dish DTVPal DVR Topic! - Page 417
post #12481 of 16895
Originally Posted by J-D-H View Post
That very last bit throws me. My clock is now at least temporarily accurate via a few recent changes here, but I fear this would reverse at any time (it all depends on which of two CBS stations my DVR finds attractive to use for TVGOS data on any one day). So now I don't know whether to enable updates at 6:30 PM as you suggest, or disable it. What do you foresee possibly happening with updates enabled when the clock is at least temporarily accurate?
The update from Austin is that this auto-reboot method no longer works reliably so I have stopped using it. I think the timestamps must be skewed sometimes even during prime-time. I say this because even the manual intervention of changing time-zone (or zipcode) and then changing it back, no longer works reliably either. I have attempted several times in the middle of prime-time, with no affect on clock skew. I know I should fire up TSREADER to confirm what's really happening, but I haven't bothered.
What used to work in Austin is what Mark is describing to you in his post. Under those conditions, timestamps from about 5pm to 11pm were not skewed while timestamps at all other times were skewed. The clock smoothing algorithm in the DVR prevents it from taking immediate advantage of the clean timestamps starting at 5pm so what was needed was a way to force the DVR to drop its TVGOS time lock and re-acquire it during the "clean zone". This could be done manually using the zipcode or time zone trick but that required manual intervention every day sometime after 5pm but before the desired evening recordings started. Mark suggested a way to automate this process using the auto-update feature and that worked pretty well for a while...
So to answer your question, no harm will come from triggering the auto-reboots, but if you've found a solution that doesn't require it I certainly wouldn't recommend it. Also, if the WUSA clock skew issue is some completely different animal than the KEYE clock skew issue, the auto-reboot solution might not do you any good anyway. But it terms of recommended timing the auto-reboot would have to happen AFTER the "clean zone" of unskewed timestamps started (thought to be around 6:30pm now), but at least 5 min BEFORE the intended recording starts. Doing the reboot after primetime would be pointless. You might fix the clock for a brief time, but it will be hosed up again by the following morning and it will remain hosed up when your intended recordings begin that following evening. Confusing I know...
post #12482 of 16895
I'm outside of Austin so have the antenna on an amplifier. Some stations come in on their own but for some unknown reason, not K-EYE. So I put the amplifier on a timer and have it set to turn on late afternoon close to the last TVGOS data transmission. This has helped a LOT over the past few months. I don't know whether it's my system or if something has changed but lately K-EYE has been very close to the correct time. In fact a few times their clock has been FAST by a few minutes!! But I just know that if I reprogram to remove the padding on the front end, it will surely start screwing up again.
Anybody know why they were off-air just after midnight this morning?
post #12483 of 16895
Originally Posted by mabuttra View Post
The PAL prefers your CBS station simply because you entered a zip code that matches the DMA of the TVGOS data that is transmitted by that station. When you enter a Baltimore zip code, it will then switch to the Baltimore station for TVGOS data because it matches its DMA.
My CM-7000PAL never seems to look solely at the zip code setting to decide what CBS affiliate to use for TVGOS data.
I had repeatedly tried switching to a Baltimore zip code, but my clock skew (AKA error) never improved.
What I posted above (about DMAs), I posted after reading a couple of people's messages that changing to a Baltimore zip code fixed their clock skew. At the time I didn't think it made sense that Baltimore, and DC would be in different DMAs since they are so close together, but after reading about some people's "success" with switching zip codes, I thought this was the only explanation for why that worked. After seeing what you reported today, it appears to be a fluke that changing zip codes worked for those other guys.
I have also seen enough reports that some clocks are too fast, instead of too slow to conclude that this isn't the same issue that Austin is seeing, so there is no point in trying to use the updates setting to force a reboot at a certain time, since there is no telling when, or if, the clock is ever correct. Also from what jrpastore said, it doesn't appear that works for him any more either.
Mark
post #12484 of 16895
Since you have been trying out the Baltimore zip code, I think I would disable updates, until you figure out whether that is a workable solution.
The reason 6:30pm was picked, is because it is after the TVGOS downloads end, and before the prime time shows come on. Prime time is when most people record stuff, and need for their clock to be right. Only you can tell if the reboot solution works for you. If your clock isn't correct, or doesn't stay correct all evening after a 6:30pm reboot, then the clock skew issue you are seeing is different than what Austin sees. I believe jrpastore has been using the "updates reboot" method to keep his clock correct in the evening.
Mark
Wonder of wonders, it has been a whole 2-3 days and our clock is still accurate to within a few seconds. Currently updates are ON, and as of yesterday the update time was scheduled to be at 6:30 PM as suggested.
Since I consider the current setup here to be a house of cards (and will feel that way for a long while yet), I'm reticent to change any settings. I'd hate to upset those cards by disabling updates !
post #12485 of 16895
Originally Posted by gary-in-dc View Post
My DTV-Pal has been running from ontime to 4 mins. ahead of real time since those AVS members contacted WUSA-9 and they did something to correct it. It used to be always slow by a couple minutes to 5 minutes. Today it is 2 mins. fast Better to have programs start a tad early then late I guess but I had to delete and re-create my timers again!
I am wondering if any of the drift is individual DVRs clock since you mentioned differences in multiple units. I don't know how the clock actually works on these things.
I'm glad to hear that we weren't the only ones to see the clock flip from being late to being early. As you say, maybe WUSA did in fact do something recently.
post #12486 of 16895
Originally Posted by AV Empiricist View Post
To differentiate between TV Guide listings and PSIP, I simply looked 4-7 days forward. No flaky info disappearing acts have ever occurred in my guide listings.
All three dvrs are keeping perfect time. (One is still set to a Baltimore zip as a precaution). So, among three of us (i.e., gary-in -dc, J-D-H, and me), the attempts at resolving the time skew for DC have met with dramatically different results. All of my antennas are essentially UHF. At 12 miles from VHF 7 & 9, it's no problem but VHF 11 & 13 are more than twice the distance so it takes more effort to bring them in cleanly (with UHF antennas). There could be more than one source of this time skew problem, but I'm suspicious it has to do with each Pal's schedule for time updates. Since one of my dvrs never skewed and another was corrected by changing my zip back and forth, is the solution to revert to a DC zip at an optimum time of day? My update option is disabled and has been forever. Why ask for trouble?
J-D-H, since my time skew was resolved with 0 reboots, I suspect resetting the zip is the key element here. The prima-fascia evidence is that signal quality may be a factor in setting the TV Guide station but signal strength isn't. For me, 9 was at 98-100 and 13 was at 73. I picked up the Baltimore time and Guide on the first try without a hiccup. Although, when I attempted the same exercise a while later, the change wasn't immediate.
If you're picking up a clean enough signal from 13, I doubt the DC time will wander back of its own accord. My guess is, if you change the zip back at the right time of day, the DC time will be fine. I'm still wondering if gary-n-dc would benefit from some signal attenuation.
I can't prove one way of another whether signal strength truly played a role. All I can report is changing the zip code to Balt never impacted the clock error with the antenna pointed at Wash DC. But when I pointed the antenna at Balt with a Balt zip code, bingo, perfect clock. Who knows, maybe some oddity unrelated to signal strength caused these results.
Since ch 9.x and 13.1 are above ch 7, presumably they're both actually transmitting in the UHF band. Hopefully your antenna ought to be fine for either of these CBS stations.
post #12487 of 16895
Since ch 9.x and 13.1 are above ch 7, presumably they're both now transmitting in the UHF band. Hopefully your antenna ought to be fine for either of these CBS stations.
post #12488 of 16895
Originally Posted by dkreichen1968 View Post
Both models are made by Echostar, the parent company of Dish. Since Dish no longer markets it there isn't any incentive to upgrade the software until/unless Dish/Echostar starts using them as a streaming device for BlockBuster VOD.
The fog clears - thanks. It sounds like Channel Master is simply a "re-badger" and has no real involvement with the CM-7000PAL at an engineering level. If so, too bad. Better not try holding my breath until a firmware update.
post #12489 of 16895
Originally Posted by comcastardly View Post
I searched for this but it seems that the AVS search function isn't working right now.
Just today, one of my DTVPal DVRs started giving out fuzzy, slightly lip sync'd audio. It does it on live TV, delayed TV and recorded shows too. It does it on all channels.
When I first turn on the unit, the audio is perfect but after about 10 seconds, it gets fuzzy with crackles and it sounds like a blown speaker sounds. If I switch to a recorded show, it does the same thing. Video is perfect. I tried changing the audio settings but it does the same thing all the time regardless.
The unit is connected via HDMI.
What can I do to fix this and what is causing it?
EDIT: Well, I just fixed the problem. All I did was unplug the HDMI cable from the back of the DVR while it was on and then plug it back in? Must have been a loose HDMI cable or something associated with HDMI. But it is back to working perfectly again so I am happy once again!
We've seen that lip sync problem too (usually after fiddling with pause, etc.). It happens very infrequently. All we do is turn the CM-7000PAL off, then on again, then click on "Resume" to begin watching where we left off. Always works.
post #12490 of 16895
Originally Posted by WillN937 View Post
I have a DTVPal DVR and a DTVPal Plus both connected via composite to a Panasonic DRM-E85. If I record something using the Pal+ the picture looks almost as good as HD. If I transfer something I recorded on the DVR to DVD it is obviously of lower quality. All I can deduce from this is that the analog converter in the DVR must not be very good.
We have a similar setup here, but I never tried what you suggest figuring the quality of the resulting DVD would be low. Glad to hear otherwise -- great tip!
post #12491 of 16895
Originally Posted by jrpastore View Post
Sounds like you're almost out of the woods! Good luck...
Yeah, you do have that backwards. Dish/Echostar is certainly the developer of this DVR. It was originally called the TR-50 by Echostar, later the DTVPal DVR when Dish was selling it directly, later (briefly) the Freestar DVR when Dish stopped selling it directly and they were distributing it exclusively through Sears/K-Mart, and most recently the CM-7000 now that their latest OEM distribution channel is in operation. Kinda gives you the impression that this thing is an unwanted orphan doesn't it...
I wouldn't feel too sheepish about the purchase though. The only real alternative (HD OTA DVR) is TIVO and I they've got their own issues. My parents have been through 3 or 4 of their TIVO Premier boxes in the last couple of years. The Cust Serv Rep at TIVO even acknowledged that they've had "a lot of stability issues with that model". So don't feel bad, you've got similar functionality, similar (maybe fewer) frustrations, and a wad of cash still in your pocket!
So as they say, "go and be happy". Well I think I can do that, at last since our clock problem is now sorta-kinda fixed.
Thanks for the lineage explanation. Yes, it does sound like this box has been unwanted and passed along from company to company. I attribute this to the general lack of interest in O.T.A. broadcasting compared to cable/sat TV.
I've heard that more and more folks are dropping their cable accounts (cost, technical problems, etc.) or their sat accounts (cost, rain fade, snow on the roof, etc.) and coming back to O.T.A. now with ATSC and all of its benefits. I'm always surprised by how many people don't understand that the digital conversion gave rise to maybe 3 times the number of available channels (at last count, over 40 viewable in the Wash DC area). When I explain these things, it's always interesting watching the wheels go round, and them calculating how much they could save each month in $$ and hassles. Maybe if enough do this, the CM-7000 will become less orphaned (I know of very few local cable users who own DVRs, and they all regret the loss of their VCRs).
post #12492 of 16895
At this point I have the firmware updates (and accompanying reboots) enabled at 6:30 PM. Our clock is now accurate, but I don't yet know if this is because of or in spite of the reboots. I intend to wait a week, see if the clock accuracy is stable, then try disabling updates and see what happens.
Even if only from technical curiosity, I still wish I understood more about the TVGOS programming data and time updates. Evidently they send data 8 times a day (always? sometimes?). Isn't this more than enough to do the job? It would be interesting to try to estimate the amount of binary information represented by 8 days of programming from 40-50 channels and sub-channels. My guess is the number would be trivially low by computer standards. It's a total guess, but 50 channels x 8 days x 48 half-hr segments (at most) x 100-200 bytes/each (pure guess) = a few megaBytes. If I didn't slip a decimal point, this number wouldn't be low by old NTSC vertical blanking period data transmission standards. However with modern ATSC, the fact that the CBS affiliates may be having bandwidth problems in getting this data to us seems hard to believe. However I suppose I must believe it -- our DVR clock seems to have proved it.
post #12493 of 16895
Mark
Soon I'll try disabling the updates. My guess (and hope) is that you're right and we'll see nothing much happen to the clock.
post #12494 of 16895
...By the way, do you ever have program details show up when you highlight a program (in the guide) and then almost immediately disappear before you are finished reading the description and then not being able to get it back even if you highlight another program and return to the previously highlighted one to finish reading the description? ...
I see it with some frequency on PSIP listings but it usually come back fairly quickly.
post #12495 of 16895
.... I attribute this to the general lack of interest in O.T.A. broadcasting compared to cable/sat TV.
I have had a number of people like telephone repair men and other technicians who see my antenna and assume I have some sort of transmitter. I said something to one person about free HDTV and he assumed I was stealing cable some how.
post #12496 of 16895
If you will look back in the thread for a few months you could find full 24+ hrs logs with the info how TVGOS data/timestamps distributing in Bay Area with normal accuracy.
post #12497 of 16895
That's really sad.
post #12498 of 16895
You're right, the total bandwidth requirement for the TVGOS datastream is a trivial fraction of the total 19 Mbps bandwidth available to every ATSC broadcaster. The problem is not that the TVGOS datastream is hogging the ATSC bandwidth. The problem is that IF the local broadcaster has over-allocated his 19 Mbps and has almost no reserve capacity left in the stream, THEN the ROVI encoder will buffer its TVGOS datastream (guide and clock data) and trickle it out into the 19 Mbps ATSC stream on a "space available" basis (It's like flying standby during during the evening rush, you may have to wait a while). Most broadcasters leave a considerable portion of their 19 Mbps un-allocated, I've seen some up to 25% or more. Our local CBS affiliate typically only has about 1% of their 19 Mbps available as "reserve". These are the kinds of things that can be measured with the free TSREADER-Lite program and an ATSC tuner card (or external USB tuner).
post #12499 of 16895
Seems that the DVR was a great thing for us.
How Big is your antenna? that anyone noticed and did not know it was an antenna?
post #12500 of 16895
It is easy to tell whether enabling updates is needed or not. Turn on the DTVPal at 6:15 pm. If the clock is right, then no 6:30pm reboot is needed. You could even do this two days in a row, just to be certain.
Mark
post #12501 of 16895
Your channel estimate is off by about 500. The DTVPal is one of the few TVGOS devices that does not support cable. Cable channels can number in the hundreds. The TVGOS data includes all cable channels as well as OTA channels. Even though I'm OTA only, my channel lineup on the Sony DHG contains over 500 channels.
Mark
post #12502 of 16895
I have both the DTVPal and the Channel Master CM7000 CECB (among other CECB's - and also, an E85H, among other HDD/DVD recorders).
If recordings from the DTVPal Plus CECB look that good to you, try recording HD broadcasts from a CM7000 (over s-video, it's best output) to your E85H, instead. That oughta blow your socks off.
HD recordings from the DTVPal don't even come close in my experience. In fact, I would rate the PQ from the DTVPal CECB as no better than "middle-of-the-pack", compared to the other CECB's I've used. It's pretty soft (yes, I only have the older, "standard" Pal CECB - but it's been confirmed by many that the Pal Plus has the exact, same PQ as the standard model).
If recording to DVD doesn't even fare as well from the DTVPal DVR, I don't think there's any way I'd be able to handle that.
post #12503 of 16895
After the official analog-to-digital changeover, Channel 7,9,11 and 13 (ATSC broadcasts) returned from UHF to their VHF High Band frequencies. All of my antennas are well designed for the UHF band but all have been demonstrated to fall-off as frequencies approach the VHF Band. In spite of this, reception on 7 & 9 are perfect because I'm only 12 miles from the DC towers. Channels 11 & 13 are 27 miles away. That's a significant distance for an attic-mounted UHF antenna to reach into the VHF High Band. With perfect positioning, 13 registers an SS of 86. (2,45,& 54 can hit 98-100) . But to optimize other channels, I accept a clean SS of 73. There's no trouble receiving my Guide info from the weaker station.
I would hope the Pal was designed to lock onto the time according to zip code. People near the time zone boundaries might otherwise be stuck with the wrong time from a strong signal across the boundary.
It will be interesting to see how this resolves for you and gary-in-dc.
post #12504 of 16895
Originally Posted by Rammitinski View Post
I have both the DTVPal and the Channel Master CM7000 CECB (and an E85H, among other HDD/DVD recorders).
HD recordings from the DTVPal don't even come close in my experience. In fact, I would rate the PQ from the DTVPal CECB as "middle-of-the-pack" compared to all the other CECB's I've tried. It's pretty soft.
If recording to DVD doesn't even fare as well from the DTVPal DVR, there's no way I'd be able to handle that.
Yeah, it's a shame that the Pal has no S-video output. There is no comparison between S-video and composite. My work-around is to route the component output to a Philips dvd recorder and output the Philips S-video to a panasonic dvd recorder. It seems to be as good as a direct S-video connection.
post #12505 of 16895
That's similar to how I route all my SD sources to my 50", HD display through my Panasonic recorder (in through s-video, and out through HDMI, or at least component).
Really does make a difference.
post #12506 of 16895
I'm pretty sure the muxer is a part of the station's equipment (for 100 %), so the 'buffering' is gonna be a responsibility of the station engineers. Same time I would blame ROVI not to been cautions when wrote they own SW and didn't predict the obvious case of delay all TVGOS packets include timestamps and does not set appropriate expiration time on those (TTL = 15 ) !
post #12507 of 16895
Great points...however....
I once owned 4 different digtial to analog boxes including the CM7000, Zenith, RCA and Pal boxes and they all pretty much had their pluses and minus's.
The CM7000 was the only one with the S-Video which if you had a TV or other divice that accepted S-Video you got a better picture but that was about the only thing it did better. The Pal box had a better program guide and locked the signal better (Better Tuner). It also had a better remote. That's my opinion from my experience. On the otherhand the RCA box was better for my mother and the one she got from me because the remote was easier to use, simpler, and had the biggest buttons for use by older folks...and the tuner was not all that bad.
Also if you have both an analog TV and a digital TV in the house, the PAL DVR and the Pal converter box make for easy transition from one to the other due to the similar functionality.
post #12508 of 16895
ST. LOUIS-(BUSINESS WIRE)- Nearly two years after the digital TV transition, antenna sales are exploding as Americans migrate back to over the air reception. This has led antenna manufacturer, Antennas Direct, to its eighth year in a row of double digit growth, with $8.7 million in 2010 revenue and a forecasted $21 million in 2011 revenue, where sales were up 225% in Q1 alone.
To make the digital transition possible, the nation's broadcasters invested $15 Billion dollars in rebuilding their stations. That investment is already paying major dividends as Americans become captivated with digital TV. In fact, the rush back to over-the-air is generating panic in pay TV providers, who for the first time in history, lost a record number of subscribers in 2010. It has also been estimated that 1.6 million people will cancel their cable or satellite by the end of 2011, according to the Convergence Consulting Group.
In the midst of this phenomenon, FCC chairman Julius Genachowski continues to assert that over-the-air broadcasting is no longer needed and consequently should be barred. These assertions are 180 degrees from the reality occurring in living rooms across America. As Antennas Direct's growth demonstrates, the pace of antenna sales are convincingly accelerating as people cut the cord. Viewers appreciate that not only does Digital TV offer improved picture quality, more channels and greater reliability, it's also free to the consumer - an important feature during a time of such economic challenges.
According to Richard Schneider, President of Antennas Direct, Experts have been telling me for 8 years that OTA was dead, yet we have maintained 110% compound annual growth since we started, earning multiple honors on the Inc. 500 fastest growing list. So the uninformed statements by the FCC Chairman are nothing but regurgitation of outdated notions from the waning days of analog TV.
Schneider goes on to point out that for legions of Americans, over-the-air digital TV is the new basic cable. Digital TV is the new disruptive technology, terraforming the media landscape, said Schneider. Think about it. Is it really surprising sales are exploding, considering the Billions invested by broadcasters and the cluelessness of the cable TV companies?
This year we are on pace to liberate nearly 1 million Americans from an unhappy relationship with their pay TV provider while putting over $1.1B annually back in the pockets of our customers, said Schneider.
http://www.antennasdirect.com/blog/a...ales-boom.html
Antennas Direct is only one company. (Channel Master, AntennaCraft, Winegard, Digitenna, etc.) They probably do have the most aggressive marketing though.
post #12509 of 16895
My DTV-Pal has been running from ontime to 4 mins. ahead of real time since those AVS members contacted WUSA-9 and they did something to correct it. It used to be always slow by a couple minutes to 5 minutes. Today it is 2 mins. fast Better to have programs start a tad early then late I guess but I had to delete and re-create my timers again! .
I'd rather miss the beginning of the show rather than the end. Who would want to see two extra minutes of commercials at the beginning, only to miss who the mystery and unlikely killer was!
As for the clock skew, I think switch to B'more zip code did work, just not right away.
post #12510 of 16895
I don't do it very often (basically to record House while I record/watch Chuck and How I met your mother). My only point/observation was the the PQ recording to the HDD on the E85 using the composite input from the Pal+ was a lot better than playing a recording on the DVR and recording the composite output. E85 is set to XR mode with 480P output. Not saying it is as good as having an additional HD recorder but I am mostly a time shifter so I rarely create a DVD. SO if I know I will want a DVD of something I try to use the Pal+ E85 combo instead of trying to dub from the DVR. The obvious problem with this scheme is that I usually don't know I want to save something until it is too late.
  Back to Forum: HDTV Recorders
