Originally Posted by
n0qcu
Not quite. It's not ATSC its QAM.
True, I missed the output scheme from my original search/forum statement (looking for 8VSB) of two years ago(told it was 8VSB and cost was $1000 so I stopped at that). But, the plan was to xmit HD video(and audio)over existing RG/6 cable. My inexpensive bedroom Vizio E320VA has a clear QAM tuner(as do many other TV's) so the zeevee box should be an acceptable alternative.
According to:
sneals2000
"QAM, 8VSB, OFDM, QPSK, 8PSK etc. are all different ways of carrying (or modulating) a digital data stream over radio waves. They each have different advantages and disadvantages, and thus different schemes are used for cable, OTA, satellite etc.
QAM is used for digital cable in the US, 8VSB for OTA in the US (and COFDM for OTA in Europe and other parts of the world)
Because the broadcasts are digital it is possible to re-broadcast them in a number of ways. In some cases you can take the entire transport stream from one source (say 8VSB OTA) and remodulate it with few changes using a different system (say QAM digital cable. You needn't touch the mullticasting or video compression at all - though you ARE likely to have to modify the accompanying service data carrying information like broadcast frequency, logical channel number etc.
You may also decide to just carry some of the services if the original source is multicast - so you may strip out the MPEG2 video and audio streams and re-multiplex these, still not touching the video compression, so causing no quality loss.
OR you could re-compress (or rate shape which allows you to reduce the bit rate without de-compressing and re-compressing) if you want to reduce the data rate of a service OR you need to move from constant bit rate to stat mux variable bit rate, or vice versa.
So bottom line - 8VSB->QAM can be done losslessly, or it can be done with a quality change, it depends on the demands of the application..."
Equally unless one wants to repeat a TV show from PALDVR to PALDVR, QAM is another way to go.
