Originally Posted by LuvMyDVR33
I'm confused about why there is still talk about this update setting being useful. If a DVR isn't always connected to the internet, there is no way to get anything updated anyway. The TVGOS doesn't need an internet connection and is NOT firmware. There is not going to be a firmware update, so no one needs the updates enabled. Here is the definition of firmware. It has to be something that operates the DVR, and TVGOS is just info, it doesn't control any functions itself.
"Firmware is programming that's written to the read-only memory (ROM) of a computing device. Firmware, which is added at the time of manufacturing, is used to run user programs on the device. "
They aren't enabling firmware updates to get firmware updates. They are doing it to take advantage of a side effect of enabling updates, and that is the automatic reboot that happens at the time of day that you specify. The theory is that if you reboot the DVR every day when the WUSA time stamps are correct, the clock will stay correct. The reboot causes the DVR clock to immediately synchronize with the TVGOS timestamps.
Mark
Just added this to the macro on my remote. Works great! Some one get this man a beer!
