Originally Posted by mabuttra
From what I've been able to tell, it is the actual listing data that causes the TVGOS logo to appear. The listing data is sent out 8 times per day. The first one of the day occurs at 12:56 am, and the last one of the day is at 4:41 pm. Each download lasts 25 minutes. If you do a "Factory Defaults" at 5:00pm, you will not get the TV Guide logo until after 1:00 am (8 hours later). There is numerous data that they could have used to trigger the TV Gude logo. Data such as GMT timestamps that are sent out every 15 seconds, zip code packets which are sent out every 30 seconds, timezone packets which are sent out every 30 minutes (the timezone packet is what causes the clock to grey out, and then it can no longer be set manually), and various other pieces of data that are sent out at various times, but the DTVPal programmers chose to have the listing download trigger the logo.
Mark
Mark
On top of that, when you change the ZIPCODE or do a reset to factory defaults it has to find the station that is sending data for that DMA. It can take a while and you don't know whether there is no signal or the DVR just can't find it. Right now I don't get a signal from the Dayton station but can sync with Cincinnati within a few hours.
