Originally Posted by
mabuttra
golinux
phildaant
Isn't the DVR supposed to do that in the background like it does with TVGOS to get the schedules?
Evidently not. When I looked in the guide this AM only 2 channels were populated. Looked a while later. No change. Then I thought to cycle the live channels and voila. When a station is tuned, the info appears in the guide immediately.
I had forgotten, but a couple of weeks ago, someone on the
CM-7000 thread was having the same problem. I don't think he found a solution though.
Mark
You may need to take action to get the Pal to realize TVGoS is gone. Try going to the screen to set the time. If the clock is grayed out, you need to do this.
First try deleting the channel that used to send TVGoS (usually your CBS station; sometimes PBS), setting your zip code to 00000, and rebooting. That should unlock the clock. If TVGoS is gone, you can add back the station you deleted and it should stay unlocked. (If TVGoS isn't gone, your Pal will gray out the clock again as soon as it detects TVGoS, even if the zip code is 00000).
If that doesn't work, a factory defaults reset should do the trick. Once the clock is unlocked and the TV Guide logo is gone from the guide, the Pal should start building the guide by scanning all your channels.
I don't know how often the Pal scans and which tuner it scans with, though. I'd
guess that it uses the same tuner used for live viewing, so it'll only scan if it's in standby and not recording two channels at once. If I'm right, you probably need to set your Pal to turn itself off after a few hours of inactivity, so it can get the chance to scan and update the guide. And I'd
hope that when those conditions are met, it scans every few hours to keep the guide reasonably complete.
But if it only scans at a certain time of day (say, overnight) and your stations are only sending out, say, 12 hours of EPG, you may have little if any guide data when prime time comes around. If this is a problem, you
should be able to force a channel scan just before prime time by scheduling an auto-update (which forces a reboot). I haven't tried this, though.
