Featured Stories
Related Forum Threads
- Wireless IR Repeater Help...PLEASE!!! Last post on 3/8/13 at 6:04pm in Remote Control Area
- Buffalo IR/Samsung Frustration Last post on 2/21/13 at 11:17am in Dedicated Theater Design & Construction
- Recommend me an HTPC remote with RF and IR Last post on 3/1/13 at 7:20pm in Home Theater Computers
- Going from IR to RF...Which remote will do it all and not break the bank. Last post on 2/19/13 at 10:05am in Remote Control Area
- IR Extener/Repeater for Denon AVR 1612 Last post on 1/26/13 at 3:16pm in Remote Control Area
Related Reviews
The Official AVS Dish DTVPal DVR Topic! - Page 524
Gear mentioned in this thread:
- mabuttra
- Trader Feedback: 0
- offline
- 1,866 Posts. Joined 1/2009
- Location: Wichita, KS OTA (w/optional cable connection)
- Select All Posts By This User
Same scenario this AM. Except for those stations that are going out over 12 hours, there was "no information available" across the grid. A quick cycle through all channels populated the missing data. I'm a little hesitant to try JHBrandt's suggestions because the clock is workable and I don't want to end up in a worse situation than I am now.
All my stations have at least 12 hours of PSIP data. When I turned on my DTVPal a few minutes ago, and brought up the guide, the grid is completely filled out to midnight tonight (some stations have data beyond that). Mine definitely does channel scans when it is turned off.
Mark
- dattier
- offline
- 2,350 Posts. Joined 3/2008
- mabuttra
- offline
It seems like lots of markets have stopped getting TVGOS recently. Milwaukee TVGOS data ends at 4:00 AM Tuesday. I forced a reboot due to an unresponsive DVR, and the TVGOS logo still reappeared, along with data till Tuesday. I wonder whether that means the local TVGOS provider is still running the equipment, but Rovi stopped sending the guide data?
A reboot of the DTVPal does not lose the TVGOS data that is in the Pal, although the TV Guide Logo, and the listings takes about 10 minutes to return. Only a factory default will erase the TVGOS data. So that is not an indication of whether the data is still being sent. Having data only until Tuesday, is an indication that the data has stopped in your area.
Mark
- WillN937
- offline
- 711 Posts. Joined 9/2008
- JHBrandt
- offline
- 699 Posts. Joined 4/2008
The TV Guide logo will disappear a few days after TVGoS does. See if it lets you set the clock, though. Even after the Pal gives up on TVGoS for the guide, it often gets "stuck" trying to set the clock from the no-longer-existent TVGoS stream. It's been reported that the Pal's internal clock isn't very accurate, so if it's not syncing to PSIP data, your recordings will soon start & end at the wrong times.
But if it ain't broke (i.e., your Pal's clock is accurate and you're getting all your PSIP guide info without having to surf through all the channels first), there's no need to do anything to fix it.
- dattier
- offline
- P Smith
- Dr. FixMyPal
- offline
- 1,233 Posts. Joined 4/2003
Mark
- golinux
- 100% Windoze-free
- online
- 846 Posts. Joined 5/2008
I just checked and my clock is still locked. But the time has been reliable for several days now since TVGOS went away. Unfortunately, (as previously noted) the guide is only populating when I tune to individual channels. If I try to fix the grid problem what are the chances it will screwup the clock's stability?
- jrpastore
- offline
- 231 Posts. Joined 8/2009
I think you're right. Both of my DVRs exhibited this "blank until tuned" guide behavior as well as clocks that have gone from 70s fast to 90s fast over the past few days. So I decided to do a factory reset on one of them and compare results:
Reset DVR: Clock is now about 30s fast and has remained so for 3 days. Clock-Set menu option is now un-grayed-out (as expected). Guide shows all channels populated for the full 12 hours required of PSIP even when no channels have been actively tuned in over 12 hours. (The ABC affiliate shows guide data out 24 hours and the FOX affiliate goes out a full 48).
Un-Reset DVR: Clock now about 100s fast and when the DVR is first turned on after being un-used for at least 12 hours, all guide data will be blank except for whatever channel it was on when it was turned on. Subsequently tuning in each channel (even for only 1 second) will result in the PSIP data for that channel populating the guide.
So I went ahead and did a full reset on the other DVR and it has behaved the same as the first one. I'll go out on a limb and recommend that everyone do a full factory reset of their DVR after their local TVGOS well runs dry. That seems the safest way of ensuring that the flaky firmware retains no "memory" of the fact that it once lived in a TVGOS environment.
Channel Master suggests disabling the TVGuide.
The TV Guide function can be disabled in the CM7000PAL by using the following steps on the remote control:
Menu>Preferences>Guide Display, then select “TV Guide” with the left and right arrow keys, and press the Down arrow to change it to “Disabled”.
Your CM7000PAL is now set to display available PSIP data.
- dattier
- offline
Tuning to the station itself doesn't make a difference for me.
- JHBrandt
- offline
Our Univisión station (which has no subchannels) WGBO and the SD subchannel of our Unimás channel WXFT have no PSIP guide info on the DTVPal DVR, though guide info for both comes in on the television's own tuner if I bypass the DVR. Two other ATSC tuners in the house can get the guide for WXFT-SD but not for WGBO.
The problem with WGBO doesn't seem specific to the Pal. Could be something hinky with their PSIP. I suggest contacting WGBO and letting them know their guide is only working on one of your TVs but other stations work on all your TVs.
WXFT is more puzzling, though. I assume you just have the same program on different subchannels (one SD and ohe HD), but the Pal only shows guide info for the HD channel, while all your TVs show (identical) guide info for both channels.
I'd try deleting both subchannels of WXFT, rebooting, then adding them back to see if it makes a difference. If that doesn't help you may have to rerun the setup wizard or do a factory default reset (which reruns the setup wizard).
- golinux
- 100% Windoze-free
- online
Like you I was hesitant to do a factory reset. But a while ago, I was feeling adventurous and tried a few things. This should work for you too since we are in the same market. First I disabled TVGOS as TalkingRat described here. The clock was still grayed out. Then I changed the zip code to 00000. Clock still locked. Next I tried a soft (power button) reset. The 'loaded please wait' screen sat there forever and I thought maybe I had bricked the DVR. But finally it started to search for stations. The soft reset unlocked the clock in conjunction with the other two changes I made in the menu. And the clock is no longer 1 min fast. I guess I'll find out in the morning whether the 'no information available' behavior is fixed.
- P Smith
- Dr. FixMyPal
- offline
TVGOS Tables/Packets Statistics:
IDs tables packets bytes known type
ID00: 211 1779 4853 [Empty]
ID26: 301 3853 1161634
ID66: 48 2800 162272 [LineupSelPkts]
ID67: 528 6800 1941616 [LineupPkts]
ID68: 16 16 7040 [DPP]
ID69: 672 6060 2568528 [ID70]
ID70: 1431 10029 5458353 [ID70]
ID71: 1278 10512 4906392 [ID70]
ID72: 177 1746 679533 [ID70]
ID73: 80 272 248176
ID74: 16 32 22304
ID75: 16 16 5136 [EPP]
ID77: 300 300 44400 [ZipcodePkts]
ID78: 16 16 2464 [TimezonePkts]
ID79: 100 300 123600 [HostSchedulePkts]
ID80: 27 51 46650
ID81: 1284 16475 5001733 {Sony FW}
ID85: 13 323 52156 [ID27]
ID86: 51 219 205011 {Ads}
ID87: 126 126 49077 [ID97]
ID88: 3 3 141 [ID97]
ID89: 2329 7832 7247522 [ID97: ImageFrag]
ID96: 1554 1554 383082 [ID97]
ID97: 6 18 17208 [ID97]
ID98: 2072 9128 8320505 [ID27]
ID100: 7807 30842 31379487 [ID27]
============ fake IDs =======================
ID254: 1935 1935 38700 (Timestamps)
ID255: 7941 7941 119115 (Dummy)
Total:30338/120978, Size:70196688
For Mark: Warning: Spoiler! (Click to show)
UpdatePkt (FW ?)
LineupPkt +
LineupSelPkt +
StationPkt
SchedulePkts
ShowPkts
DescPkts
CastPkts
ZipcodePkts +
TimezonePkts +
HostSchedule +
EPP +
DPP +
SortControl
ImageFrag +
System ?
Setup ?
Some are known to us. Perhaps the DVR has hidden TVGoS debug/stat screen.
Edited by P Smith - 1/21/13 at 7:30pm
- jrpastore
- offline
In terms of clock stability, I don't see any real benefit to avoiding the factory reset option. Consider:
If you leave the clock "locked" by not doing anything after TVGOS disappears, then the DVR clock will continue to drift gradually (7-10 sec / day fast seems to be the consensus result). At that rate, within a month your clock will be off by about 5 min which is the max you can compensate for using the auto-padding option. So after that you'll be forced to use manual timers and go back and rename all your mis-named recordings, etc. Even if you're like dattier, and don't mind doing this, within another month or so after that, you're clock will be so far off that keeping track of your schedule will be unworkable. In short, "something must be done!"
Whether you decide to unlock the clock through a factory reset or some combination of tricks makes no difference, you still end up with a clock that is driven by some weighted average of PSIP times in your area. There is no option in the DVR firmware that gives you full manual control over the clock. You can change it (once you unlock it from TVGOS) but it will immediately start changing itself based on PSIP input.
So once TVGOS dies in your area you have two choices: Do nothing and have the DVR clock drift into uselessness within a couple months, or throw yourself on the mercy of your local PSIP data. There is no third option. Since we're all going to be forced to end up with option 2 within a few months anyway, I think the cleanest way of getting there is the full factory reset. We know the firmware is not very robust, so why invite trouble by using tricks to unlock the clock. The least fault-ridden route through the buggy firmware in a PSIP only environment would have to be booting a factory fresh unit into that PSIP only environment, not trying to trick a TVGOS locked DVR to stop looking for TVGOS timestamps.
- mabuttra
- offline
If I recall, there were several people who reported that, after (temporarily) losing TVGOS for more than three days, their DTVPals did not pick the data up again when TVGOS was restored. It was as if the DTVPal stopped searching for it. Perhaps this is what is happening when TVGOS stops completely. After three days it not only stops scanning for TVGOS data, but also stops scanning on its own for PSIP data.
- mabuttra
- offline
Let us know whether the clock is still unlocked the next time you check it.
- LenL
- offline
- 951 Posts. Joined 11/2008
- Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
I will watch the clock issue and as I see it get messed up I will do the reset.
- golinux
- 100% Windoze-free
- online
- JHBrandt
- offline
It also resets all Pal settings to their defaults, so after you do one, you'll have to disable firmware updates again, reset the appearance of the guide, reset the padding for recordings, etc. So even though your recordings are safe, it can be somewhat of a hassle. I suspect that's why many folks are reluctant to go for the factory reset if there's a less disruptive alternative.
One reason I can think of for people avoiding a factory reset unless it is a last resort is you will lose all of your set program timers. For those that have a lot of recurring timers set it will require that they all be re-entered after the reset. Personally this doesn't really matter to me as I set most of my timers on a one-time basis depending on if the show I want to record is a new episode or a repeat. I use tvguide.com to get the new or repeat show information prior to setting my timers.
On another note we still have TVGOS here coming from WBZ channel 4 in Boston, which is a CBS owned-and-operated station. I'm waiting for TVGOS to abruptly end anytime between now and April and then make the change to PSIP only, as some of you are already experiencing.
- jrpastore
- offline
Most of us are doing exactly that twice per year anyway because it is the most reliable method of crossing a DST transition.
- phildaant
- An Ant
- offline
- 1,764 Posts. Joined 11/2005
I think if you'd substitute the word "some" for "most" you'd be much closer to the truth. Some (probably most) of us have no problems at all with the time change. Like any other problem with these devices, you hear most from those with trouble, and nothing at all from those with little or no problems.
I did a factory reset first, before TVGOS had actually disappeared, because it was locking up so much. I didn't write down exactly what I did in what order, but at one point I did have clock access, changed it, and then TVGOS came back and reclaimed the clock. TVGOS ended early this morning, so I tried a soft reset with TVGOS disabled and zipcode at 00000 -- and the clock is grayed out still.
I won't bother with another factory reset yet, since PSIP clock averaging should work just fine here. Diagnostics shows 12 PSIP stations, nearly all within 2 seconds. Two are off 20-28 seconds, in opposite directions. There's only one really bad time, off -10566, and given there's a weighting function, I am assuming this one is thrown out.
Now that I need to pay attention to the clock, I miss not having a clock display.
PSIP on the weekend tends to fall apart for a couple stations. Fox lost all guide info a few days ago, and they didn't fix it yesterday. Two stations do 3 days, what a difference that makes!
I only have trouble with DST in the Fall, and this year, they all got it right.
- Pete-N2
- offline
- 436 Posts. Joined 6/2009
We have established that newly located stations are added to the top of the list. On a power fail or warm boot the order of entries on the diagnostic screen reverses. So if you have so many entries that you overflow the buffer, do you get a different channel list after reboot?
- P Smith
- Dr. FixMyPal
- offline
- JHBrandt
- offline
The thing is, I know they can get it right if they want, because they send correct guide info to Zap2it. Unfortunately, they've never been on TVGoS, so on the Pal I've always had to put up with their PSIP guide.Agreed. Some DFW stations do 3 days, such as KDAF/33. That's handy because subchannel 33.3 isn't on TVGoS either, but I can still look on Friday & plan ahead through Sunday.
- The Official AVS Dish DTVPal DVR Topic!
Recent Discussions
- › The "Official" NAD T 747 Owner's Thread 33 seconds ago
- › Looking to buy first HD TV, need some pointers 1 minute ago
- › Getting HDTV outside 1 minute ago
- › 110" DIY Spandex AT Screen 1 minute ago
- › XBMC Mediaserver + NAS or Plex? 1 minute ago
- › 2013 IZOD IndyCar Racing in HD 2 minutes ago
- › Official Samsung UNxxES8000 Owner's Thread 2 minutes ago
- › F8500.. OR .. ZT60 ????? 2 minutes ago
- › Official OPPO BDP-103 Owner's Thread 2 minutes ago
- › #### The ULTIMATE Bass Demo Disc #### 2 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
