Originally Posted by
Jack Morris
Utoh... looks like the TVGOS end has finally hit Houston?
Yesterday, I noticed that the guides for all the stations higher than 8.1 PBS were "No Information Available". Then, around 6pm, suddenly we had info for all the major networks through midnight or so.
Now today, we have no guide for the low numbered channels but have it for the channels which were missing it yesterday.
Suddenly, while I was scanning forward and backward in the guide, program info started to magically appear? Now, we have program info for all the channels up to 9pm... and it seems to be appearing bit by bit as I watched the PG?
What in the world is going on???
I've seen several similar reports; apparently when TVGoS quits (temporarily or permanently), the Pal gives up trying to download TVGoS data after a few days, but it doesn't automatically load PSIP guide data for the stations that used to be on TVGoS. It will only load the PSIP data as you scroll through the guide.
To get it to load PSIP guide data automatically, you have to make it "forget" TVGoS. A factory defaults reset will do this. An alternative that has worked for some is to delete the channel that used to host TVGoS, reboot, and add it back. If that works, you only lose timers for that station, rather than losing all your timers.
There have also been some who've reported losing TVGoS guide data but not the TVGoS clock. If this happens, a factory defaults reset may not work - as soon as the Pal sees the TVGoS clock data, it'll start expecting the guide data again; if that never comes, you'll just be back where you started.
To guard against this, you can set your zip code to 00000 during the factory defaults reset (or after deleting the TVGoS channel but before rebooting). That way, the Pal won't recognize TVGoS data even if the host station hasn't removed their TVGoS equipment yet.
Jack Morris
Are there any options for having a guide in these units such as connecting it via ethernet cable to the internet or something like that?
Unfortunately, no. In theory it's possible but it'd require a firmware update. Since the Pal is no longer manufactured, the businesses that sold it have no interest in ordering a new firmware update from the manufacturer (Echostar).
Jack Morris
Thanks for the help!
One other thing. I don't think any of us yet know how often the Pal will automatically load PSIP guide data. Since many stations only provide 12 hours of guide via PSIP, if the Pal doesn't reload the guide often enough, you may see little if any data in the guide depending on how long it's been since the Pal last reloaded it. The guide should fill back in up to 10-12 hours as you scroll through it. Luckily, some stations broadcast more guide data (typically 24-72 hours), but you may need to "linger" on a station longer for the Pal to receive all its guide data.
Edited by JHBrandt - 2/6/13 at 11:19am
