Originally Posted by byucougar
I am getting my DTVPal DVR tomorrow, and I am planning to set it up with the following parameters. Please let me know any other recommendations to give me the best chance of being problem free
Plug into UPS
Place on laptop cooling pad in an open cabinet
Remove smartcard
Disable automatic updates
Use actual zip code
Do not plug in ethernet connection
Do not update Firmware (hopefully it comes with F201)
Connect with composite cables
Use PSIP only (Buffalo does not have TVGOS data)
Plug into UPS
Remove smartcard
Use actual zip code
I set up my second batch DVR last night with the above parameters and have not had a problem yet. I recorded a show, watched and paused another show while it was recording and then watched the show while it was still finishing recording. It is far from a comprehensive test and I am not a big TV watcher, so it will not get much use other than recording a few kids shows to use as incentive to do their chores in a timely manner and the few sporting events that are still available OTA.
My software version is F201TALD-N
Factory Reset was another suggestion, but I will not try that unless I run into problems.
I successfully set timers for different times of day on the same station with one big block of "No Information Available" in the guide at all.
Thanks for taking the time to make that post. It answered every question I had about the unit - many that never would have been addressed by the manufacturer. I think I'm gonna get one.
