AVS › AVS Forum › HDTV › HDTV Recorders › The Official AVS Dish DTVPal DVR Topic!
The Official AVS Dish DTVPal DVR Topic! - Page 7
post #181 of 17068
Originally Posted by bfdtv View Post
akbungle,
Could I get your permission to link one or two of those pictures in the first post?
Please do!
post #182 of 17068
Originally Posted by OhMyTVC15 View Post
Ah...but what guide updates? TVGOS or PSIP?
I think it must be for TVGOS because (I think) PSIP can update any time.
post #183 of 17068
Sorry this is probably a dumb question (I probably know the answer from reading between the lines)
I thought this was an Digital Converter box so the signal coming out of it was in Analog?
But it sounds like that the signal can be either Analog or Digital (or even HDMI)?
So this mean it works with current HDTV's?
I also heard you need a G-Link or G-Wire, do I really need that, what is it used for? To connect a VCR?
Anybody using this in UTAH?
post #184 of 17068
Thanks for all the photos, nice to see what the unit really looks like
post #185 of 17068
Yes, PSIP is pretty much constantly updated/provided via OTA signal.
post #186 of 17068
All outputs are live, both the digital and analog. So yes, it's also a digital converter box. Works with SD & HD TVs and monitors. Don't need "G".
post #187 of 17068
Originally Posted by dagger666 View Post
In the review of the tr-50 on youtube they said the USB port is for connecting external storage device to incress storage.
That was the "alpha" unit that was demonstrated at CES last year. I'm curious about what features exist in the "shipping" unit.
The physical port is in the back, but from early reports there is no USB supported connectivity with this current firmware version, although the port is hot.
post #188 of 17068
The physical port is in the back, but from early reports their is no USB supported connectivity with this current firmware version, although the port is hot.
I think for right now the port is used for updates with a USB stick for those with no ethernet. Updates via usb will be available at the DTVPal website though the first update isn't there yet.
post #189 of 17068
Originally Posted by nolim2873 View Post
I tried that, setting my Dish 625 to another address, but the DTVPal's remote was still controlling the 625. (I think, I'm not, that Dish's receivers respond to remote address 1 from an IR remote regardless to what they are set to - perhaps a safety feature.) I had to change both to an address other than 1.
I suppose the difference is that my 625 was set to 3 and 4 before I setup the DTVPAL DVR. I've never had your issue - in fact, I have even tried setting the 625 on the DTVPAL and DTVPAL on the 625 on the Aux remote code and it worked fine.
post #190 of 17068
Has anyone managed to get the case apart to see the inside?
post #191 of 17068
sorry if this question has been answered... I couldn't find the answer on dtvpal's website. Is there any way to transfer your tv recordings to a computer? Thanks!
post #192 of 17068
No.
If you haven't already, be sure to see the first post, as that includes answers to some commonly asked questions.
post #193 of 17068
I was able to sneak away quick to take these pics of recording menus:
I was attepting to tune in a third show, I know it is not possible just curious what it would do.
bfdtv I hope this was what you were looking for. Happy Holidays everyone!!!!!
post #194 of 17068
Thanks for the additional photos
I noticed your background colors are different than the 1st set of pictures, is background color selectable?
post #195 of 17068
I can pick up stations in different markets. Will the guide show more than one market? What if one of the markets does not have a carrier for TVGOS...will information from the PSIP integrate into the TVGOS? Or, will I need to use the PSIP guide instead?
Thanks, and Merry Christmas!
Bill
post #196 of 17068
No our NBC affiliate uses Grey bars on SD most of the time. The other aspect to color was that my lights were on a bit in my theater room and I have a front projector.
post #197 of 17068
I was referring to the purple background vs. the blue one in the original post. maybe it's just different lighting in the room or your set may be calibrated differently. The OSD is blue over the last photo, perhaps the screen shots you posted are in fact more purple?
Anyways if it's not selectable, it's not selectable...
post #198 of 17068
Can you change the channel sort order from descending to ascending? E.g., 11.2, 11.1, 9.2, 9.1, 5.2, 5.1, starting at the top of the page becomes 5.1, 5.2, 9.1, 9.2, 11.1, 11.2?
P.S. akbungle, nice job with the pics!
post #199 of 17068
^Yes
post #200 of 17068
Sorry I edited my post but I guess not in time.
Yes different lighting in my room is all. The first photos were more accurate.
post #201 of 17068
No.
thanks! oh i did read the first post...guess i had overlooked that paragraph part and skipped straight to the FAQ
post #202 of 17068
Yes, depending on what you want.
The RCA audio and video composite out could be connected to your PC. Played in real time.
HD to your PC is a different story.
post #203 of 17068
So my unit just came in. A couple of observations after 10 min of playing with it.
1) The picture quality is on par with the tuner in my Sony 34XBR960. I am more than happy.
2) I updated the firmware, quite easy to do.
3) The unit seems to run the same with or without the smart card in it. I guess it is for future functionality (VOD or PPV or whatever)
4) You can rename each channel manually
5) I noticed under the HDD section of the diagnostics menu, there is an option to reformat the hard drive. Good to know.
6) Overall first impressions are very favourable. More than happy with the purchase (so far)
post #204 of 17068
Anyone have this hooked up to an analog TV? I sure hope the pq is better than the DTVPal. Gawd my UPS man is slow!!
post #205 of 17068
For those who have Dish service you can program your sat reciever remote (vip 722) to operate the dvr. go to page 81 "programing to control a second satellite reciever to "AUX" woks great.
post #206 of 17068
I have a question, I haven't experimented with yet.
If you pause tv for two hours; What happens if the show is longer?
Does it start dropping the beginning of the pause or does pause just stop?
If someone knows great. I may try it later to satisfy my curiosity.
ps: I haven't programed my tv in the remote but it will already turn it off/on, volume, mute, which are all the functions it can control anyway
post #207 of 17068
With the VIP 722 you can only pause for 1 hour. If you know you are going to be away long just record the program.
post #208 of 17068
Page 13 of the manual says you can pause for up to one hour.
I agree with Frank43 - why not simply record the show.
post #209 of 17068
Ahh, I read the manual, online, back in November and must have forgot that. So after an hour it just stops? Do you loose the paused data?
Didn't say I wouldn't record. Just searching for limitations of different features.
post #210 of 17068
Just to clarify: The guide will only be updated from PSIP for the channel you're actually tuned to (or possibly 2 channels since the unit has 2 tuners).
  Back to Forum: HDTV Recorders
