AVS › AVS Forum › HDTV › HDTV Recorders › The Official AVS Dish DTVPal DVR Topic!
The Official AVS Dish DTVPal DVR Topic! - Page 112
post #3331 of 16890
Originally Posted by becat View Post
Anyone else get the following error if you try to change the length of currently saved timer? It says "The selected event is already recording error anyone?" I was trying to change the show "24" to 2 hours from 1 since its a two hour show next week. I'm thinking it has to do with with my PSIP data that I only get about 24 hours for Fox.
Anyone else having this problem? Any work arounds outside of deleting the recording and setup the recording again.
That used to be a problem but not anymore.
The only differences:
- Updated to F202
- TVGOS was enabled in my area
Since I update to F202 the same day TVGOS showed up, I do not know which one fixed the problem.
post #3332 of 16890
TVGOS solved it, not the fw update.
post #3333 of 16890
Agree, I am running on 202 and not getting TVGOS, thus this problem. Either Dish needs to fix this bug or I need to somehow convince my CBS station to step up. Neither is looking very good at this point.
post #3334 of 16890
Originally Posted by Rammitinski View Post
Original aspect ratio.
post #3335 of 16890
The Kuros are priced very, very reasonably these days.
Both Pioneer, Vizio and LG have recently announced they are getting out of the plasma business altogether (sucks, I know. Plasmas are actually selling better than ever . . .
I think that leaves only Panasonic and Samsung as the PDP panel producers. The new high-end Panasonic plasmas have performance (and price tags) that look to match the Kuro. The price of plasma came down much faster than anyone expected and are readily undercutting LCD on price/performance. It's just that when you go into a store, there are 10 LCD display models for every plasma, and the sales people push LCD.
Four years ago I was looking at a displays marketing report that said plasma was in decline and 1080p plasma would never be more than a niche product. I often wonder why we spend a lot of money for these idiot marketing reports.
post #3336 of 16890
PBS does TVGOS in my area. You might want to give your local PBS folks a call.
post #3337 of 16890
Really? Can anyone else confirm this? I thought PBS did the analog TVGOS and only CBS did the digital.
post #3338 of 16890
I am now in possession of a UPS call tag. Problem is I am not sure if I should use it. My unit averages a reboot maybe once a day (on bad days, sometimes 2-4 reboots). I am worried that I may get a unit back from Dish that is worse than my current one (see posts on this thread where people with replacements are still getting reboots.) Should I play DTVpal DVR Russian roulette?
post #3339 of 16890
I can confirm that here in Buffalo PBS is indeed broadcasting digital TVGOS, here's an email reply I got from the director of engineering at WNED here in Buffalo in response to me asking if he knew who was broadcasting the TVGOS signal:
Dear Mr. XXXXXX,
WNED is indeed broadcasting the digital TV Guide On-Screen data. It went on-line about two weeks ago on channel 17-1. You didn't mention whether you are viewing over-the-air or on cable - I don't know if Macrovision has arranged with Time-Warner to pass the data on via their cable network.
I hope this helps -
Best regards,
Joseph C. Puma
Director of Engineering and Technology
Western NY Public Broadcasting Association
WNED-DT/TV/AM/FM & WNJA-FM
Erik
post #3340 of 16890
Both Pioneer, Vizio and LG...
Oops - originally just had the first two brands in there, then remembered the third, and forgot to take off the "both".
Yeah, there's a recent running thread in the "Flat Panel General" forum about it: http://www.avsforum.com/avs-vb/showthread.php?t=1123689.
post #3341 of 16890
I'm really happy that I have several CRTs to use up before I'll need to be buying a new TV. By then the dust on Plasma/LCD should have settled.
post #3342 of 16890
Originally Posted by chapelrun View Post
First, the Tan colored power board has on it "DESIGNED IN 2008" - - This is printed on the TAN Board itself. On a white sticker in the corner it reads "Assembled in China TA L2" and the board details are on another white sticker "164272-02 and RR64272T03115L"
Chapelrun and I are having a close look at my "K" unit and comparing it with his photograph of the power supply. We have come to the conclusion that the power supply in his "L" unit and my "K" unit are IDENTICAL. They are the same all the way down to the part number. Only the serial number is different. Both say ""Assembled in China TA L2". The sticker he referenced above reads "164272-02 and RR64272T00028K" on my unit. Does anyone think I got the 28th "K" power supply off the assembly line? Perhaps Chapelrun got the 3115th unit from the "L" run?
Also on the Green board is another white label that says "Assembled in China TC L3" which seems to be just the assembly data for the Green board itself.
My "K" unit says "Assembled in China TA L2" on the green (main) board, just like the power supply. This sticker in hignfy's excellent photograph of his "L" unit reads "Assembled in China TA L3".
Originally Posted by hignfy View Post
Here's with the cans removed
tiny url.com /7cudke
Comparing this photograph of an "L" unit to my "K" unit we see the following:
- hignfy's power supply board also appears identical.
- Both main PCBs say "SCH 162506 PWB 162507". This, along with other markings, makes me think they both have identical printed wiring boards (not necessarily identical assemblies, though).
- The assembly numbers on the main board are different. hignfy has 167517-02 while I have 163940-08. We have looked all over the board and only find one difference (which does NOT mean there are not others): On my board, the ONLY chip with a label reads "K163949. 71BD" and has a red dot on it, which may contain the firmware, reads "K16751?. ????" and has a blue dot on hignfy's.
- My serial number for the green board is also quite low.
The bottom line is that there are NO obvious hardware differences between a "K" unit and an "L" unit and the power supplies are most definitely IDENTICAL.
post #3343 of 16890
Originally Posted by 123abc View Post
Off current topic, but has anyone who orderd the DVR from dishdepot the week of 15th Feb. received any response? Unit shipped? They are telling me they had a problem with my credit card going through and it should have shipped today, but I have not received the tracking number.
Go it today. So far, no reboots . Happy.
post #3344 of 16890
I don't have a TVGOS (Digital or analog) device yet. But on my PC using a Fusion card and TSReader lite sw, I can see the data streams, and my local PBS (Indianapolis) is sending the digital TVGOS. So perhaps there is something to this.
post #3345 of 16890
does anyone know if they {dishdepot} are still selling this unit ??
If so I am tempted, just to access the dual tuners that
are needed for my HDTV ready Sony, that could well
use a 5th or 6th gen tuner chip. Please correct me
if I am wrong.
were closed..... and do not reopen till Monday>
Then I could just hope to get a unit that does the DVR
function; sadly, it sounds as though you could almost consider
that an "extra" at this time.
post #3346 of 16890
I got a replacement recently and haven't had an issue -- so far in 10 days of use. My earlier unit was a piece of junk that never worked.
Probably worth trying. You've got nothing else to lose really if your current unit is already rebooting.
post #3347 of 16890
Excellent post. Very obviously some of the posts that thought the "K" units weren't defective while the "L" units were are basically as much of a myth at this point as the "solutions" some have tried to fix the unit's problems (like plugging it into the wall, or a power strip, etc.)
I think the bottom line is that, unless some markets have cleared up how TVGOS is transmitted, some units are working and some aren't -- and if it's not a hardware problem, then we're probably just grasping at straws to explain what's not working in them.
post #3348 of 16890
Originally Posted by honeymonkey View Post
el gran chico,
Thanks man, this is exactly the feedback we need. Let me know if you start locking up again the way you have it set and we'll compare notes. I may have to adjust mine if yours works out. In the mean time, I'll keep mine where it is at just for consistancy.
Do you receive TVGOS in your area? or did you just leave updates on because you don't?
Hey honeymonkey, 5 days now and 0 lockups, 0 reboots! Yes, I get TVGOS. I left updates on because I want to try one thing at a time to isolate it.
post #3349 of 16890
Thats Great! looks like we may be onto something. I have another guy trying same settings, only with some reoccurring timers. At any rate, its a dam site better than the daily reboots and freezes.
Thanks for the report.
post #3350 of 16890
Could someone post the settings with the highest probability of avoiding reboots? That is, if there is a consensus about such things?
post #3351 of 16890
My old unit was plugged into a wall, plugged into a power supply, I disabled updates, re-enabled updates. Didn't matter -- rebooted every time, on every kind of programming.
The new replacement unit I have works perfectly. And I've plugged it into a wall, plugged it into a power strip. I enabled updates for a few days, dis-abled them for a few days -- all to try it out. So far, no matter what the circumstance is, I've had not one issue with it.
Thus, I think it depends on whatever unit you have. There's no harm in trying some of the solutions out if you've got a bad unit, but from my experience, I think it's safe to say it's a crapshoot and a some of these solutions are kind of like grasping at straws. Some units work, some units don't. I think ultimately that's what it comes down to, regardless of the settings (power strip, no power strip, hanging it upside down, right side up, lol). And if it's not hardware related perhaps something changed with how TVGOS data is broadcast because I'm not sure it's a coincidence some units are all of a sudden behaving better roughly since that date.
Either way, good luck!
post #3352 of 16890
I did finally see two reboots with mine the other day, about 4 minutes apart - while I was using it. I say this because after each I checked the power cycle count and it incremented for each, The counter is now at 12 (since 12/23). At about day 9, it was at 9 so I thought it was about once per day (and I don't remember if it started at 0 however). But then it stopped incrementing except for once (going to 10). None of these were while I was using it.
About two weeks ago I did finally disable updates because I got tired of seeing a couple of "Ethernet connection lost" messages each night while using it. This appeared to make that message go away because I haven't seen it since.
At the time of the reboots, I was watching an hour show. It was not recording anything at the time. Each time it downloaded the program guide. Also each time it remembered where I was in the show (actually about 30 seconds before the reboot). So at least I didn't have to find my place. You just have to be real careful to select "Resume" and not "Start" (Resume is the default on the Dish satellite DVRs, but Start is the default on the DTVPal DVR).
The only thing I could think of that was different was that I was watching the show during the day (around 1-2 pm). Previously all my watching was in the evening (while it may have been recording on one or both tuners) and I never saw a reboot. So maybe the other 10 reboots occurred during the day when I wasn't not using it. That was on Wednesday afternoon (3 days ago), I have not seen a reboot since then (again all watching in the evening, including Lost and Life on Mars while it was recording Wed. night as an 8:00-11:00 manual timer - I started watching at around 9:30 fast forwarding past the first hour).
post #3353 of 16890
post #3354 of 16890
Originally Posted by kjs0812 View Post
Need a Pal Dvr -
http://cgi.ebay.com/DTV-PAL-HD-DVR-F...3A1%7C294%3A50
I love how they advertise "150hr". Not many will record ANY SD much less a lot of it.
post #3355 of 16890
The only SD is some of the smaller networks and the sub-channels. So that means you can record up to 150 hr of a weather subchannel.
post #3356 of 16890
I wish more stations would have a SD sub-channel. So much content out there is broadcast in "HD" but is actually SD at the source and 4:3 as well. An example of this would be "Cheers", "Hawaii 5-O", and the like.
And what gets me even more is when something that was shot in 16:9 HD originally, but in syndication is clearly SD in quality and cropped to 4:3 but broadcast in HD so it takes up a lot of space on the DVR and crappy SD quality to boot - the worst of both worlds. "House" and "Criminal Intent" are repackaged just like this.
post #3357 of 16890
if I am wrong.
I ordered mine on 2/26/09 and received a tracking number with 3/9/09 as the UPS delivery date.
post #3358 of 16890
I'm sure you are correct. I, on the other hand, record mostly SD content. I typically have about 190 recordings on my 500GB-upgraded unit.
post #3359 of 16890
Thank you so very much for that information; I will call them Mon. AM.
The EBay "no return" does not interest me, for if I am not blessed with
a smoothly working unit, I can run up my post count on this board descriping
the tribulations of returns and the results to be had with the latest replacement
unit....
Too bad they didn't get it right from the get-go.
post #3360 of 16890
Originally Posted by mpmp0 View Post
my program guide won't populate itself and the TV guide logo does not appear on the guide page (i'm using the DTVPal's guide).
i've tried my zip code and zip codes in the Loop but the guide still will not fill in.
if anyone in the Chicago area/'burbs has had success with the guide populating itself and the TV guide logo appearing, would you please tell me the zip code you are using to accomplish this.
thanks.
It works for me. Try 60187.
  Back to Forum: HDTV Recorders
