Originally Posted by cavemaster
I appears that the firmware has greyed out the toggle on the "DVR" choice. I suspect this is where you might have access to select the choice of your external media, once enabled.
Attachment 127713
Attachment 127713
Did you change the repeat back to one time and see if the toggle will work? Mine shows DVR / Autotune (original firmware). It seems like that this would be the place that you could specify where to record. Hopefully, if / when USB support is added they will have a default option (I.e. largest drive, internal / external, etc)
), and initial observations are favorable.
