DB100,
Thank you for your explanation, but, I must not have stated my question well enough. I understand the process of both changing the Remote, then, changing the DVR to comply.
But...
What was the original setting for the Remote ?
If I select a entry for the Remote, see that it doesn't work, and decide to give up on it, then...
What number should I enter, or sequence should I perform, to return the Remote to it's original setting ?
Have a good Day !
S.W.
But...
Have a good Day !
S.W.
the ABC station and its data from the Guide it displays. Still that way as of this morning, so I conclude the ABC data is totally missing from the TVGOS stream.
