hello, i've had my dtvpal for about 9 months - it has been working great - its a f202 version (i'm afraid to upgrade to the f209, i've heard of many problems after doing a upgrade) - as i said its been working great, then a couple of weeks ago it started rebooting itself, not to often sometimes twice a day, somedays not at all - then yesterday the remote seemed to stop working - i have a sony tv working on pals remote also, everthing was working fine - then as i said the remote seemed to quit - i soon realized that i could only turn pal off\\on if the tv was off (if tv was on, i could not turn pal off\\on) - and most of the time all the buttons would not work on pal but would operate the tv just fine - then i realized the the remotes buttons for operating the pal would work if i had the remote about an inch away from the pal recievers window - it seems like, somehow the sony tv is overpowering the pal - i've put knew batteries in remote, i am useing pal's remote - i'm wondering if somehow the infered signal between the tv and pal somehow crossed - is there away to remove my tv's info from my pal remote - i've tried redoing the tv to the remote, it didnt change anything - anyone else haveing this problem, any idle of a way to fix this - i really like this unit - i've phoned the rep's, they are useless - thanks for any and all help
post #8161 of 17068
12/14/09 at 6:57pm
