LED, Mode, Power Consumption:
* 'Green', 'ON' (Not recording), ~22.5 W / ~37 VA
* 'Green & Red', 'ON' while also 'Recording' , ~22.5 W / ~37 VA
* 'Red', 'Recording' while in 'Standby', ~22.5 W / ~37 VA
* 'Off', 'Standby' without any other activity, ~19.5 W / ~32 VA (see Note 1 below)
* 'Off', 'Standby' with background activity, ~22.0 W / ~36 VA (see Note 2 below)
Notes:
1. With a Western Digital model WD10EVDS 1 TB HDD installed in place of the factory supplied 250 GB
(WD2500AAVS) HDD, the Standby (without any other activity) power consumption is ~18.5 W / ~30VA.
The ~ 1 W power savings is due to the drive's IntelliPower mode when it reduces the drive's
rotational speed from 7200 RPM to 5400 RPM.
2. The background activity in Standby can be due to downloading TV Guide 'TVGOS' data (but not PSIP
data downloads), scanning for new channels (yes, this occurs in Standby), etc.
Note: With background HDD activity the power consumption is also ~22 Watts with the 1 TB drive.
3. The only way for the DVR to be fully OFF (Not drawing AC power) is for it to be unplugged.
Caution! Before un-plugging the DTVPal DVR, the DVR should be in Standby (Power Indicator OFF,
Not Recording) for at least 1 minute. Then pull the AC power plug straight out quickly
in single motion (to limit power transients into the DVR due to intermittent arcing at
the plug). Then wait 30 seconds (for Read/Write Head to Park) before moving the DVR.
4. The DTVPal DVR's AC input Power Factor is ~ 0.61 PF.
Notes:
