Originally Posted by Fastslappy
the klipsch's will be a fine choice as they are Very efficient matched with the selfpowered PC12-NSD
Polks are way over rated & are not the Polk's of yesteryear
Now the Klipsch sub woofer's aren't that good either as you see them like the Polk's for sale used all the time
The RB-51 Klipsches will really shine as they are horn loaded(that Tractrix is a beautiful sounding horn) as i have owned many of them add the RS-42's & an RC-52 center & home theater will not be the same agin for you
the RB-51 HT system minus the RPW-10 Klipsch sub is the hot ticket
as that system is the best bang for the buck
I know the PC12-NSD is priced high when looking @ other subs but the quality is there as if you had dropped alot more on other sub brands
thou I a huge Klipsch fan i cannot tell anyone to buy a Klipsch sub
Thanks for this input. I wasn't getting much over at the Klipsch thread. I listened to the WB-14 speakers but I'm not seeing much of a technical difference from the RB-51s. I'm not too picky with speakers but just need a nice upgrade and I keep hearing awesome things about Klipsch as well as SVS subs. It get hard to try to listen to each type in stores (if they even have them) and tell a minor difference.
Any other suggestions?
