AVS › AVS Forum › HDTV › HDTV Recorders › HD Cable Box Recording
post #1 of 2
Does anyone know if it is possible to record HDTV after the signal has passed through a TW HD Cable Box and before it goes to the TV?? And if it is what recorder do you use?
TIA
Hugh
post #2 of 2
Your only choice is a analog WVHS from JVC. These cost $2k used and go for about $4k new.
It will record the RGBHV or component video and l/r audio.
Try a search for JVC & WVHS for more details.
  Back to Forum: HDTV Recorders
This thread is locked
