So I just get my new XPA-5 amp hooked up tonight and I go to play some ps3 and after about ten minutes it just shuts off with a blinking red light. I unplug it and plug it back in and turn it on and the fans kick in but then it just turns off and blinking red light. I also cannot eject my gamefly disk.
I can't believe my luck the day before christmas break starts. This is a launch 60gb. I am very dismayed that my ps3 died in only 2 years at this high of cost.
Anyone have a solution for this.
Yeah, it does feel like a nightmare, doesn't it? By the sounds of your problem, the exact same thing happened to my PS3 about half a year ago. You didn't mention the yellow light, but I'm pretty what you've got is the dreaded "yellow light of death". And unfortunately, there's not a whole lot you can do to fix it. I must have tried turning mine on about 500 times!
. I would peruse the links Kess supplied. Somewhere, there is a fix that did work for at least one guy...not sure if it will apply though. If it's a no go, send'r in and get it fixed (I believe it comes back with a warranty). Play on the wifes until it returns.
