AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Not sure how to hook this up.
post #1 of 3
I am currently running a Carver Sunfire TGRIII and it has 4 subwoofer outlets.
I teasing myself with purchasing the Quad MFW-15 package.
Can i connect all 4 of these through a LFE into splitters to make one line ?
Thanks for the help.
post #2 of 3
I'm not sure I follow. If the Sunfire has 4 sub outs, and you're considering 4 subs, just use a separate line out for each.
post #3 of 3
I downloaded the manual I thought it has 3 seperate lfe channels, but anyway as schroedk says just use a seperate line for each.
