In my speaker shopping, which continues, the reviews of the GedLee speakers, available as completed speakers or in kit form, and designed by Dr. Earl Geddes, have intrigued me. I want to thank the other users of this forum who wrote about these long before I found out.
The GedLee web site
These speakers use Pro drivers and a waveguide. They are said to be very dynamic, with the ability to play very loud and very clean. Designed with HT in mind.
I've e-mailed Dr. Geddes about this thread, and he has agreed to answer questions about his products here. I'm also hoping some owners of either the GedLee Summa, Nathan, or Abbey speakers will join in and write about their experiences.
The first photo below is from the GedLee web site, the second is a picture of a customer built kit.
The customer who built that set of speakers wrote
" ... To make it short: the speakers are awesome.
If you've never listened to a speaker that is capable of reproducing such a wide dynamic range without distortion (take any of the popular 2 way boxes) then you'll be amazed how lifelike e.g. a voice can be.
The lack of compression combined with a high directivity that minimizes disturbing reflections helps in raising intelligibility not only of voices but of the whole sound stage. Normally you would have to install absorbers matching the directivity of the speaker to reach that level of intelligibility.
Furthermore the directivity is very constant so coloration from the indirect soundfield is minimized. In spite of that I've installed absorbers behind the speakers because even a 15" woofer isn't capable of following the directivity of the horn down to the lowest frequencies.
All in all this speaker is very analytic and let's you really hear what's on a recording and what stereophony is capable of. Sometimes it hurts with bad recordings but most of the time it's just a big joy.
With all that said keep in mind that the Nathan is "only" a satellite speaker that needs to be complemented with one or more subwoofers. If you're looking for a stand-alone speaker then the Abbey or Summa maybe right for you. ..."
The GedLee web site
I have reached it tonight and who would have thunk it, very small movements.
