Originally Posted by Laurent Garnier
Second problem: my connection is established only at 11 Mbps instead of 54 Mbps. I think it could be a driver problem. Between two PC with XP, I first had the limited 11 Mbps until I discovered one advanced driver parameter named "Ad-hoc Wireless Mode". This parameter was set by default to "802.11 B Only". After setting it to "802.11 B/G Mix", I was able to establish a connection at 54 Mbps between the two PCs. So, maybe there is a way to change this parameter in the Linux driver packaged in the app.bin ?
In case it could help someone, I solved this problem (bitrate in ad-hoc mode) by adding this line in my net.config:
Code:
iwpriv rausb0 set AdhocOfdm=1
Now I get nothing, it just sits at a black screen. Has anybody recovered from a froze firmware update?
