AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Firmware - Western Digital - WD TV HD Media Player
Firmware - Western Digital - WD TV HD Media Player - Page 85
post #2521 of 2569
Hello everyone! I hope you could help, i have looked through fors but I could not find an answer on firmware programming on the WD TV HD. Please excuse my English as it's not my mother language
I need the WD to autostart on repeat mode. Let me explain it: I have a single file on a USB drive, thise drive plugged into the WD. Then when I turned the WD on I want it to start automatically playing this single file and repeat it endless without touching a single bottom. I think it is just matter of changing a register so repeat mode is force to be on, but I have no clue on how to do it.
Could somebody please help me? Is there any guide or how-to in any web so I can have look? Do I have to do it on Linux or is there any way to program the firware on Windows?
Thanks a lot for your support
Kind regards!
post #2522 of 2569
I was never able to get a USB drive to work.
I ended up installing the drives in my XP box
BikerMike11
post #2523 of 2569
WD has released WDTV generation 2, is not the same WDTV LIVE. No, it's a new device with firmware 1.01.75 . So, forget new firmwares to our OBSOLETE WDTV generation 1.
post #2524 of 2569
I installed WDLXTV_LIVE-0.2.2.1, I have connected to the network, how do I modify the S00custom-options;
post #2525 of 2569
Originally Posted by thnmnt View Post
I'm hoping someone can answer this relatively simple question - Is there any reason I shouldn't use the latest version of b-rad's firmware? Like many of us, I'm stuck at 1.07 since I use a USB hub.
I am using b-rad's latest WDXLT firmware on my WDTV and the Hub works fine for me. So if Hub functionality if what you want to keep, go right ahead and flash that sucker.
post #2526 of 2569
I have downloaded and put on a flash drive
1.03.01_B-RAD.CC_WDLXTV-0.5.8.1
but now it won't mount my nfs mounts
I get the following error mesages
modprobe: module nfs not found
modprobe: failed to load module nfs
Can someone point me in the direction to fix this please.
post #2527 of 2569
Read TXT changes logs you need add more files to use NFS mounts
post #2528 of 2569
Hi all,
I have upgraded wdtv to wdlxtv 5.8.1 including ssh,nfs,wireless apps . Its connected to belkin wireless adaptor and working fine.
Recently i have deleted "config" file from conf folder by mistaken. then picture was not coming so i have manually added some entries using config tool . Now wdtv is working fine.
But I have not rebooted the wdtv after that . Now I have question that will everything work fine after reboot or not ?
If not then can anyone provide basic config file options which is required after reboot of WDTV ?
Would really appriciate your help.
post #2529 of 2569
Do you know this for sure? WD hasn't said this.
post #2530 of 2569
Originally Posted by esxadmin View Post
Hi,
this might be interesting for people from germany.
I got a Wintech LAU-15 usb lan adapter from Atelco working with ext3-boot release 0.8.5. It sells for 9,99 Euro so its rather cheap.
It is based on MosChip MCS7830 and works well.
I got aroung 14 MBit/s with copying a file from my Samba Share from a Linkstation Live.
The DivxHD sample from the Wiki played without problems.
Various 720P Movies played fine.
I'll try to get more performance figures.
Thanks for this really great firmware guys.
I was thinking about getting new external HDDs, but this isn't needed any more.
I have the same adapter and did some throughput test using 'cat' (PC→WDTV).
The result is as follows (Zorlander ext3-boot VERSION='1.02.07-ext3-boot-0.9.2').
CIFS: 12.5 Mbps
NFS (on Windows): 27 Mbps
It is possible to stream a 1080p mkv Movie (almost 10 Gigagbyte) over NFS. Not possible with CIFS.
CIFS (Windows)
NFS (Windows)
Enjoy
Teo
post #2531 of 2569
Now they have three firmwares to work on. Live, generation 1, and generation 2. Soon or later, they'll have to cut down their work. I just feel sad that I bought the WD TV generation 1 not to long ago, now i'm stuck with it.
post #2532 of 2569
I know I don't have a WDTVLive, how do I know if what I have is gen 1 or 2??
post #2533 of 2569
I put the B-rad software in my wdtv. I can see my IP number but that's all. It keeps searching and does'nt give me my shared folders in my computer. What can I do?
post #2534 of 2569
Have you specified which SMB shares to mount in the net.mount file? If not, then the WDTV doesn't actually "automount" SMB shares (god, if it did that on my home network, I'd be swamped) but only those specified in the file.
post #2535 of 2569
I did specified the mount share, like this:
xmount //192.168.1.1/D:\\Claude\\My Documents\\Movies Movies cifs
Is this correct? The movies are in "Movies" in my documents in drive "D".
That's what I put in net.mounts and it did not work.
post #2536 of 2569
I've been working and trying to make that da.. thing to work and I tried everything but nothing works.
I've tried with nfs, cifs, no results.
Though, my IP number is there and it is in my router too, that means it is well wired and recognised.
I tried with brad software and with ext3-boot.
I put nfs server and programmed it (exports file)..and it is running well.
I shared my folders. I already have a laptop with wireless and it works super and I also have a XBox 360 connected to that router and everything is all right and I have my folders on my main computer shared so the XBox can read them too, so that's why I don't understand why it does not work on the da.. WDTV.
If anyone can help, that would be a great deal.
post #2537 of 2569
Hi,
I have never been one to update firmware just because it is newer, but I was wondering which firmware for the WDTV seems to be the most stable and reliable for most people collectively.
Mine came with firmware version 1.01.02 and I haven't updated it because it hasn't caused me any problems.
Would another version improve anything and has it been trouble free?
John
post #2538 of 2569
Ko570a...I did the same and eventually added the samba.apps.bin file with my mount file to my usb drive and it worked as a cifs share. 1080p had some hiccups so I'm now trying to use the nfs shares...still some reading to do on that though. Don't know if you had done this but it worked for me. BB
post #2539 of 2569
tks Bbuk, I'll give it a try....nothing to loose. Strangely, I'm still convinced this will work..one day...
post #2540 of 2569
I guess it should be like this xmount //192.168.1.1/The_name_you_used_for_sharing_not_the_absolute_path Movies cifs
post #2541 of 2569
Then it should be ??? :
xmount//192.168.1.1/Claude/My Documents/Movies Movies cifs
or
xmount//192.168.1.1/ My Documents/Movies Movies cifs
or
xmount//192.168.1.1/Movies Movies cifs
Which one?
post #2542 of 2569
or
or
Which one? What's the right way to write it?
post #2543 of 2569
or
or
What's the name of your share? If it is called "Movies" on your network, then it's the third version. In other words, in this example:
xmount//192.168.1.1/Movies1 Movies2 cifs
means...
"I want to mount a share called Movies1 located on PC 192.168.1.1, it's a windows share and I want the WDTV to refer to it as Movies2"
I use Movies1 and Movies2 to make the example clearer - you can use the same name for both.
post #2544 of 2569
I just installed b-rad's wdlxtv. All I really wanted was the latest official firmware + hub support (for now, thinking of playing with networking at some point). Until this point I've been running 1.07, the last fw with hub support from WD.
My setup was 1 2TB drive plugged into USB-1 and a hub w/2 500gb passport drives plugged into USB2. Originally, When I clicked on USB1, I would get the contents of my 2TB drive and when I clicked on USB2, I would get 2 icons showing the 2 drives plugged into the hub (TV1 and TV2).
Now, after upgrading to WDLXTV I have some odd behavior. My USB1 shows 2 icons even though my hub is on USB2. It shows my 2TB drive plus one of the 500gb drives. My USB2 shows the other 500gb drive.
Hopefully this makes sense. Basically, I want the hub drives to show only on USB2. And since the USB1 port doesn't have a hub - to just show the big 2TB drive on that one.
Is this just the way hubs work now or is there some setting I can adjust to change the way this works?
thanks.
post #2545 of 2569
thanks.
That's just the way it is - each drive (well, technically each partition) will display individually. Unless you want to play around with "fuse" to logically aggregate multiple partitions into one (and, no, I don't know how to do it. Might be useful later though).
post #2546 of 2569
If each partition or drive was displayed individually that would be great. but instead i've got USB1 with 2 subdrives (when only one is attached) and USB2 with 1 sub drive (when 2 are attached).
post #2547 of 2569
Sounds like you have the Library option turned off. I have mine turned on, and when I go through the "Folders" option on the main menu I see the partitions.
post #2548 of 2569
I'm not sure what you mean by 'partitions'. I have 3 separate drives. Are these not simply 3 separate partitions? And of course I have the media library option turned off! It's utterly useless for those of us with large numbers of TV episodes. Each TV episode is given the same 'weight' as a movie. I guess I'll just have to get used to the seemingly random assignment of drives to USB ports.
It does seem like this could be addressed in an update as I don't really care how the WDTV sees the structure, as long as I have some control over how it's displayed to me.
post #2549 of 2569
Originally Posted by craftech View Post
Hi,
John
Does anyone have an opinion on this?
John
post #2550 of 2569
Lots of people (including me) held fast at 1.01.07 because that's the last official firmware that supported hubs. Subsequent firmwares have fixed various things - lots of subtitle help, some sync issues, gain issues...you can check the changelogs to see.
Basically, you should upgrade to the latest version - it's stable and there's no downside (unless you use hubs). If you do use a hub, you can get b-rad's wdlxtv which is based on the latest firmware but puts hubs back in - plus a bunch of other stuff.
plus - you can upgrade, see if you like it and downgrade if you don't. you just make a small text edit to the .ver file if you're downgrading.
