Originally Posted by thnmnt
Lots of people (including me) held fast at 1.01.07 because that's the last official firmware that supported hubs. Subsequent firmwares have fixed various things - lots of subtitle help, some sync issues, gain issues...you can check the changelogs to see.
Basically, you should upgrade to the latest version - it's stable and there's no downside (unless you use hubs). If you do use a hub, you can get b-rad's wdlxtv which is based on the latest firmware but puts hubs back in - plus a bunch of other stuff.
plus - you can upgrade, see if you like it and downgrade if you don't. you just make a small text edit to the .ver file if you're downgrading.
Thanks for that. Really appreciate it.
John
