AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Firmware - Western Digital - WD TV HD Media Player
Firmware - Western Digital - WD TV HD Media Player - Page 2
post #31 of 2569
Originally Posted by digicool View Post
I was seriously researching parts for an HTPC and came across this player. I thought I'd give it a try and wow! Very nice product in the price range. I am very satisfied with the product performance, especially with HD files. Thanks!
I updated the device to the latest firmware. Here are my observations:
- Like other people are saying, the device never really shuts down. It stays pretty warm even when it is powered off. I am glad its got 3 yrs warranty
- I noticed occasional random resets
- I liked the white colored subs for MKV files and how they show outside of the main picture (in the black area)
- I would like the remote button presses to be some more responsive
- Photo loads are pretty slow (my 8MP pictures take full 5s to load)
- I liked how audio continues to play even when you exit the Music page (like Windows MC)
Overall good product. I will continue to update here as I use the device further.
On the Box it says 1 year warranty, where did you see 3?
post #32 of 2569
you can change back to 1.01.01
download 1.01.01 to a seperate folder
open file "wdtv.ver" with notepad
change VERSION='1.01.01' LOCATION='wdtv.bin'
to
VERSION='1.01.03' LOCATION='wdtv.bin'
save that file and the original .bin file on a seperate flash
plug in to wdtv it will say it sees new firmware
hit enter
reboots
when done done it will say it sees new firmware (because 1.01.03 is higher than 1.01.01)
eject drive and you will be done
post #33 of 2569
Hi all!!
To extract the rootfs of the firmware, you should (from linux shell of course ):
1- Download the lastest official firmware WDTV_FW_1_01_02
2- unzip WDTV_FW_1_01_02.zip
3- dd if=wdtv.bin of=cramfs.img bs=32 skip=1c
4- mkdir tmp
5- mount -o loop cramfs.img tmp
6- rsync -avHS tmp/* rootfs/ (for edit,modify files etc)
in rootfs you'll find the firmware and the micro codes for the smp8635 and more.....
Researching........
Regards
post #34 of 2569
Originally Posted by ripkey View Post
Hi all!!
4- mkdir tmp
Researching........
Regards
Thanks ripkey,
Do you know if I can extract it with ubuntu under VirtualBox?
post #35 of 2569
Yes, you can to do it with an Ubuntu within a virtual machine.
post #36 of 2569
when are you guy's expecting the new firmware releasse
this month or later
post #37 of 2569
Hi there....
have a look at this page:
hattp://support.wdc.com/product/download.asp?groupid=1001&sid=112&lang=en
damn first post.... no urls allowed
remove the a in http
there you can find the WD TV GPL Code (140MB)
maybe anyone has an idea to customize the firmware..
greetz gooze
post #38 of 2569
Maybe a interface and functions like this:
xbmc.org/home (no www. in front of the website!)
I had this on my xbox classic, but no HD support. So i bought WD TV.
post #39 of 2569
It's a new source code. At least Bigger package than older one
regards
Temi from Finland
post #40 of 2569
The new GPL code package includes a MIPS toolchain (source and binary).
Everything else is the same.
Still no kernel config file. :-(
post #41 of 2569
I was wrong. I just checked again, it is 1 year. Sorry about the confusion.
post #42 of 2569
ScottWD, any chance of some sort of idea when the next firmware will be available? This month, next month, March?
Cheers
post #43 of 2569
Cheers
And are you planning to add support for menu's in iso's?
post #44 of 2569
thats the reason ii'm waiting for a update
that wil support dvd structuur menu's with iso en vob
then i'm totaly happy
post #45 of 2569
and a lot of people here are happy then i guess...
@ petje:
How do you watch your iso's with several episodes now?
I mean if you have 4 episodes and you wanna watch only episode 3?
post #46 of 2569
i watch that now on a normal dvd not with the wd hdtv
becausse my partner otherwise dont get it:-)))
post #47 of 2569
Posts related to official wishes and non-development talk
could be posted here http://www.avsforum.com/avs-vb/showthread.php?t=1100499 and read it from start (no duplicates pls)
This thread is about kernel development, technical issues
about compiling ideas about howto compile sources
sources update, and firmware update
Keep in mind
Main discussion about WDTV is here over (130pages blabla)
http://www.avsforum.com/avs-vb/showt...80840&page=130
Please keep this thread clean and do not submit offtopic posts
I do not want to delete posts, but if it becomes necessary, I will do it. Developers do not want to waste their time reading main thread about newbie issues, how to reencode movies or pust the button before ejecting the drive from the USB slot
peace and regards
3dxr
post #48 of 2569
CN4 is serial. It boots to a root shell.
By much trial and error (since WD hasn't released a kernel config file)
I managed to build a working module for one of my USB wired ethernet devices.
I also built a new busybox and a few other things in buildroot.
ext2 and ext3 are built into the WDTV kernel but the scan_manager seems
to ignore them so they are not automatically mounted.
They can be manually mounted from the shell (dunno if they work for playing
files as I just use it so far for xfering my binaries).
So, I can manually mount my flash drive and load modules (some work,
some don't) from it, configure networking, start telnetd, and telnet in.
It looks like the initrd has support for flashing / recovering from a bad flash.
I have been too chicken to try flashing a custom image as of yet.
post #49 of 2569
What is the pinout for the serial port? I've been waiting for someone to get this before getting involved.
post #50 of 2569
Originally Posted by linuxjacques View Post
...I have been too chicken to try flashing a custom image as of yet.
But some someone has to be the hero! I think, you'll get 10.000 community points (or whatever ) if you going to try is ....
post #51 of 2569
Code:
  WDTV circuit board |     CN4 pinout
                     |    | o o o o |
             CN4     |    '---------'
          '------' O |   +5V RX TX gnd
A level converter is required. RX and TX are from the perspective of the WDTV,
so remember to swap them to get the PC's perspective.
post #52 of 2569
Code:
                     |    | o o o o |
             CN4     |    '---------'
thanks, just ordered the ttl-usb converter.
Btw, have you tried backing up the firmware? even a find / | cpio -ovB -O output.cpio
image would be a start for the rest of us. As well as manipulating the boot loader to see if you can load different kernels from a prompt would be great.
post #53 of 2569
Hello,
linuxjacques > I think you can flash own kernel becouse
some people have upgrading issues with official FW and after unsuccessfull upgrade they was able flash FW again
my 1th experience with fogotten USBflashKey in side usbport
when is USBkey connected there my WDTV is not booting normal
flashing led light and will not boot to GUI
I think this is check device try to find FW files and flashing phase.
but with USBHDD WDTV is booting to GUI only with USBkey is freezing in this phase
i have 1.00.00 original WD FW
I have one wish
could you please test how fast is copying files (cca 700mb-2gb file) between USB1 USB2 HDD
also network test will be nice
I need to know if is this function usable in real world
For BR rips copying we need few MB/s
thank you for CN4 schema very usefull
BTW: in original FW image is full filelist with md5sum
I am not sure if all files are checked before flashing from memory and after successfull check phase is FW flashed to device probably you have to update also this file
post #54 of 2569
This is my current understanding of the WDTV boot sequence:
The boot loader is called zboot. I believe it is in the first flash partition (mtd1).
zboot reads hardware settings from something called an XENV block.
These are things such as memory timings.
zboot then mounts the second flash partition (mtd2) which is a cromfs image.
mtd2 contains several files, some in bin and some in xrpc xload format.
The xrpc files are signed and potentially encrypted.
One of these files is the kernel image, which is apparently signed but not
encrypted.
The kernel image is validated (signature checked I guess) and then
uncompressed to RAM and executed. The kernel image includes an initrd.
This initrd is very small and limited - I think it only exists to check the rootfs
and pivot_root to it if it's OK, re-flash if it's not OK.
The third flash partition (mtd3) contains a cramfs image of the final rootfs.
This contains the firmware for the video, audio, and demux hardware
on the SMP8635, as well as the media playing applications.
I think only the final rootfs is included in the firmware updates we have
seen so far. If you want to look at it, download a firmware update, skip the
32 byte header and loop mount the cramfs image as posted earlier in this
thread.
I have not been able to interrupt the boot sequence to get a zboot prompt.
I'm not even sure there is one. I see other similar devices include YAMON
if they want that functionality.
I think running a custom kernel would require somehow creating the signed
xrpc xload kernel image and replacing the one in mtd1. This would be rather
dangerous because bad flash recovery would be lost and if the kernel didn't
work you would have a brick which would require JTAG to fix.
A custom rootfs should be much safer and easier.
post #55 of 2569
Originally Posted by 3dxr View Post
Hello,
To be clear, this should mean we can recover from a bad rootfs flash,
but not a bad kernel flash. The updates so far have not replaced the
kernel (I think).
I have one wish
I will try these tests tonight when I am at home.
My tests so far have shown 14-15MB/s USBHDD read speeds.
I have not yet tested network throughput.
Yes, I think the md5sums are checked on every boot by the /init script
in the initrd. This file should be easy to generate.
post #56 of 2569
encrypted.
thread.
And in English ?
post #57 of 2569
And in English ?
heh, sorry about that.
Put another way:
As things stand right now, we have a good chance of eventually
being able to add our own applications and networking support to the WDTV.
This will take work and time but I think it's doable.
I think we have a not so good chance of being able to run custom kernels,
due to the security features of the hardware.
We can load kernel modules though, so that helps.
And I haven't even begun to figure out whether we can implement our own
video jukebox software.
post #58 of 2569
Well I think I have to disappoint all who hope that e.g. xbmc will run on this box.
Of course it would make this box the sorcerer's stone of hd media players, but xbmc is heavily relying on x86 hardware and gpu and is absolutely not prepared for the MIPS arch.
Of course I don't say that it's impossible but it's unlikely to happen in the foreseeable future.
But for the more realistic goals like networking support, basic remote admin through telnet/ssh seems to be achievable which will help a lot.
post #59 of 2569
XBMC or similiar mediacenter software isnt required
for so small device
I think most wanted can be
* network with sshfs|nfs|smb|ftp for remote copy
from wired PC to attached Storage (home NAS Static Dropbear ??
* filemanager MC/NC style? or simple DELETE/COPY/MOVE/RENAME on all stoages
* vlc - mplayer streaming from PC or another powwerfull player
my opinion WDC will not support IPnetwork support for this device becouse its accesories for WDHDD
thats the reason why I am not talking about DTS/and other not supported codec which will be more prefered by WDC in new Firmwares.
linuxjacques> Is it possible change XML files and add/change action and add shell script ?(USB1flash USB2HDD)
for example cp -aR /tmp/USB1 /tmp/USB2/NEW_movies
what you mean is real or we need change TVdock code
What you mean about IP unicast video streaming is it CPU available serve co high load USB network adapter and send data to DMArenderer ?
could you share which modules are not working with kernel
and whick Chipset you are using as USBnet adapter ?
post #60 of 2569
what would be the theoretical to add modules to the kernel?
