Originally Posted by bahoiz
Hi Zorander,
here the messages.txt:
and also,I couldn't see hostname and ip address in the settings/system/about.
thank you very much for your hard work on WD firmware.
Hi Zorander,
Code:
Jan 1 00:00:17 WDTV-1eace syslog.info syslogd started: BusyBox v1.10.0 Jan 1 00:00:21 WDTV-1eace user.notice root: net.agent: Called for eth0 Jan 1 00:00:21 WDTV-1eace user.notice root: net.agent: Using /boot/net.config: DHCP= IP= GW= Jan 1 00:00:21 WDTV-1eace user.notice root: net.agent: Using system hostname WDTV-1eace
I see the problem
For now, strip out ALL the comments from net.config. (Or remove it)
Next revision will fix it.
The hostname that got assigned wsa WDTV-1eace.
Settings/About only updates if the IP successfully updated.
But it can be added manually over telnet.
Even unplugging the WBTV from power and plugging it back in simply means that I get different devices with lights on before WDTV hangs. But everything's OK once I unplug the Wii adaptor.
