I need to pick up a powersupply for a new PC build that I am doing. I am a very experienced builder and understand Powersupplies.
I am just wandering if these 80 Plus Certified units are worth it economically.
If I install 500 Watt PSU that is >80% then I am wasting about 100 watts. If I went with a 600 Watt to compensate and it get lets say >65%, then I would be 210 watts. This is a difference of 110 watts.
If I left this running 24/7, I am coming up with the following math under full load.
110 watts x 24 hours x 30 days = 79200 watts / 1000 = 79.2 Kwatts
I think I am at $.15 per kwatt so that is a savings of $11 per month.
But this is under full load. I would say that it would it would only be under full load for about 15% of the time at most. The other 85% it would be relatively idle with an occasional drive access.
So I coming up with an actual difference of $1.65 (15%) and $4.25 (85% at half power).
So that is actually $6 per month. And this is assuming that the efficiency doesn't drop over time. Does it?
Anyone else have any thoughts?
