AVS › AVS Forum › Video Components › Home Theater Computers › WINDVD9 vs ffdshow
WINDVD9 vs ffdshow
post #1 of 5
I built a HTPC a while back and I really like winDVD9. I love the upscalling of the all2hd feature, although I crank it down a bit so it doesn't look too manipulated. I've recently been having trouble with it- tried to reinstall, and it says it's allready installed, even though it's been uninstalled with Revo and registry has been cleaned.
So my question is this- I know you can adjust all the video settings with ffdshow, but from what I read, it just adds an artificial sharpness to everything. What I like about the all2hd is it adds a realistic "3D" look to standard DVDs, making them look upconverted. Can I get this same effect with ffdshow?
post #2 of 5
You can do whatever you want with ffdshow, for the most part.
I'd put more faith in ffdshow than "all2hd", to be honest. With ffdshow it's just a matter of finding the right settings... that's the hassle (mostly just time consuming testing different settings - there's too damn many... that's why there's a sticky thread about it). The limit of how good the upscaling can be with ffdshow is your CPU.
post #3 of 5
From this screenshot, it looks like "All2HD" also just adds artificial sharpness (local contrast enhancement), with halos everywhere.
There's no magic to this technique; ffdshow can degrade the image in much the same way, if you like.
post #4 of 5
I'd go with FFDShow for custom filters and best of all...its FREE!!
See my screenshot here (using sharpening and color filters). Though the downside is u introduce some unwanted noise with the sharpening. But when watching a movie, this is totally unnoticeble.
http://www.avsforum.com/avs-vb/showt...719041&page=86
post #5 of 5
FFdshow will give you way better results, assuming your computer can handle the extra workload.
I am conviced the highest setting in this thread: http://www.avsforum.com/avs-vb/showthread.php?t=719041 Will look miles better than all2hd
