AVS › AVS Forum › A/V Control & Automation › Remote Control Area › RTI RP6 red IR light on
post #1 of 3
hi
I have a RTI RP-6 with 6 components running.
This afternoon my Satellite functions will not work from my remote. Every other component is working fine.
I have had a look at it and the red eye (IR) is on constantly on the Satellite. i unplugged the IR and replugged it but the red light came back on. Doesnt flash at all.
I have called my service guy but they are away until next week.
Any ideas or does it sound like my IR may be faulty?
thanks
post #2 of 3
Try swapping ir leads between that port and another, you wont have control but will see if it is a bad emitter, if it is a bad emitter then swap it with a new one and you should be ok, if it is not the emitter it might be the RP-6
Does it have the short leads on the RP-6 (about 6-8" long)?? if those are not in place you could have a damaged RP-6, the remove voltage from the outputs if only an emitter is used
post #3 of 3
Glackowitz: Thanks for the quick reply.
I swapped out and it is the emitter. Funnily enough when i swapped back its now working ok. I will get the engineer to swap it out for a new one next week though.
Thanks for the advice.
  Back to Forum: Remote Control Area
