AVS › AVS Forum › Audio › DIY Speakers and Subs › Noob needs some help - sub building
post #1 of 3
I'm very sad that my PB12 died... Instead of buying another sub, I was told I should consider building my own..
Can someone link me to a FAQ or something along those lines? I'm hoping to learn the basics so I can decide if I want to build one myself.
Also, if you can link to some vendors for amps/subs or recommend some brands I should be considering.
post #2 of 3
i suppose you could search the forum. i believe this question gets asked routinely.
also outline how much you already know about subwoofers so we can establish a starting point for you.
post #3 of 3
Also, how much you know about basic construction and power tools. Also which tools you have access to
And your budget.
