Is it possible to play a PAL DVD (of a TV show from 1997-2000 era) using ZoomPlayer?
Will the normal DVD codecs do the job? Will it look ok and sound ok?
Unsure if this affects anything, but I've got an older MITS WS-65905 65" 1080i from 2000 that I feed a signal to from ZoomPlayer thru component.
It's based on an internal CRT that is particular about which frequencies. I have my screen setup as 720 x 480.
I'm using reClock to get sound to work, and also have no idea how PAL would affect this.
Wish there were a way to test it (any idea where I can buy a single PAL DVD?)
